588,337 active members*
4,652 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > smallest cnc router CR2030 for Plywood cutting
Results 1 to 2 of 2
Threaded View
    Jul 2012
    83
    X,Y axis working area
    300 x 200mm
    Z axis smallest cnc working area
    <60mm
    Table size
    370 x 440mm
    Max. speed
    0 - 4,000mm/min
    Max. working speed
    0 - 4,000mm/min
    Working delicacy
    0.015mm
    Reposition accuracy
    0.05mm
    Max. Feeding height
    60mm
    Command
    G code *.u00 *.mmg *.plt
    Software
    type 3 , Artcut, artcam,Ncstudio
    Max. power consumption
    1.2kW
    Spindle
    0.8KW variable speed, water cooled motor
    Spindle speed
    24,000rpm
    Work type
    stepper
    Relative humidity
    30% - 75%
    Working voltage
    AC 220V, 50/60 Hz
    Weight
    57kg
    Manner of receiving data
    USB OR PCI
    Running circumstance temperature
    0 - 45°C
    SAMPLES
    AFTER SERVICE
    Guarantee for one year.
    24-hour technical support by email or calling
    I f necessary,we can send our technical personnel to to your country to offer help.
    CERTIFICATE
    CE&FDA
    KEY POINTS
    Please kindly tell us your engraving or cutting materials, and materials’ size.
    Then we can quickly check and recommend to you the right machine with right working area.
    We can change all the parts of the machine according to customer’s request,such as the spindle (air cooled or water-cooled optional ),guide rail (linear guide rail or square linear guide optional ), the motor (step motor or servo motor optional), the table size of the machine and so on. If you are interested in our products,pls contact me.We are looking forward to cooperating with you.
    Any other doubts, just feel free to let me know,Thanks for your kind attention!
    Attached Thumbnails Attached Thumbnails WK2030 CNC router ??.jpg   photo on stone.jpg   2.jpg   3.jpg
  1. Problems cutting MDF and plywood
    By davtuner in forum DIY CNC Router Table Machines
    Last Post: 01-30-2013, 12:09 PM
  2. Cutting .25 in plywood
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-27-2012, 09:09 AM
  3. Replies: 6
    Last Post: 05-11-2010, 09:07 PM
  4. What's the smallest size cnc router needed to cut a guitar
    By macgemby in forum Musical Instrument Design and Construction
    Last Post: 11-08-2008, 09:52 AM
