The tube and PSU are going in the bin
I have now gone paranoid about tube temperature, totally anal.
Question: I plan to add a thermal laser shut off switch shortly after the tube outlet. I can switch at 60 or 70degC (140 - 160degF). Which would you use?
I've also ordered a radiator, a fan and a panel themometer.
I dug out a flow meter from my junk pile, then decided it would be much easier to make a little pot with a hole in the bottom. If full it pushes down on a microswitch and gives the laser an okay to cut. I can 3D print it and make it integral with the hose clamps.
