I am a long time user of RhinoCAM 1.0 on Rhino (3 and 4) without any issues
Recently I upgraded to Rhino 5 and finally installed RhinoCAM 2012 (lucky for me I kept the old Rhino 4 on the system).
The steps I have taken and the issue is this:
1. I started Rhino5 (with RhinoCAM 2012) and made sure all the units were set to inches
2. I drew a test part (shown below as part)
3. I set up 2 simple profiling operations and ran a simulation in RhinoCAM which worked fine (shown below as simulation)
4. I posted the results using Mach3-inch in RhinoCAM 2012 and got the file (shown below as Part (RhinoCAM 2012_Rhino 5).txt)
5. looking at this file it is not going to run much of anything, to make sure I loaded it into Mach3, started up the system and tried a test cut. As expected nothing moved.
6. I took the same part file and brought it up in Rhino4 (with RhinoCAM 1.0) and generated the following output (shown below as Part (RhinoCAM 1.0_Rhino 4).txt)
7 Set up the same test cut on the CNC and it worked perfectly as expected from looking at the g-code.
In both cases I'm running RhinoCAM 4 and 5 on a Pentium 4, g GHz machine running WinXP SP3
Anyone seen any issues that are remotely like this or have any suggestions as to what may be happening?
Thank you,
Steven
