588,626 active members*
5,742 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Improvement for anyone using a CNC Router Parts machine with prox limit switches
Results 1 to 11 of 11
Threaded View
    Jun 2013
    22
    I am a new CNC user and just completed my CNC Router Parts CRP4848 build. When I bought the kit, I went ahead and sprung for their proximity limit switch kit as well. I really like them but hated the metal brackets they send with them. I was constantly bumping them and then my switches would be out of place and not work.
    So, for one of my first real projects on the machine, I sat down and came up with a new bracket and thought someone else might benefit from them. They were cut from 3/16" acrylic since that is what I had on hand as scraps! They work awesome and have just enough give in the acrylic that if I mess up and hit the limits when jogging a little too hard, they will give and not break. You will have to change out the bumper screws since they will not be long enough with the new brackets but that is simple.
    Anyway, here are some pictures of what they look like installed on my machine.
    Attachment 190714
    Attachment 190712
    Attachment 190716
    Attachment 190718
    I have attached the dxf file if anyone wants to use it.
    Attached Files Attached Files
  1. Machine Zero On A Mill Running Mach3 Without Limit Or Home Switches
    By xxtoni in forum Mach Software (ArtSoft software)
    Last Post: 02-26-2013, 07:46 PM
  2. CNC Router Parts breakout board Limit switches
    By Plan_B in forum DIY CNC Router Table Machines
    Last Post: 04-24-2012, 03:43 AM
  3. E-Stop,Limit Switches - Car door open switches ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 04-19-2012, 09:55 PM
  4. Limit/home switches on converted machine
    By hobbybob1 in forum Mach Mill
    Last Post: 02-08-2011, 02:30 PM
  5. Limit switches don't stop the machine
    By dfv in forum Mach Mill
    Last Post: 01-25-2011, 10:22 PM
