I have a problem with booting my ez-trak dx 2 axis and need help.
The problem has been started with the mis counting of the z axis . When i set the z-axis to zero and go down it was reading oke but when i raise it and lower again to the same point the dro is of about 1 mm.
After a couple of reboots i have still the same problem but the rest of the machine was working oke.
the next day when i started the machine the x axis value is fluttering on the DRO and i normely get a message to home the machine i get nothing.
When i press 3 to move abs it displays the message "[power-on] failed".
After a couple of reboots I check the machine parameters and the were totaly messed up, luckily i had the parameters written down a while ago .
so i did set the parameters back to the right value and after reboot the machine was working again.
But the several days later i have the same problem again. i set the paramaters again but now i can't get it to work.
when i load the pfm file and select tune it is waiting for bmdc but it looks like the computer can't find it.
I don,t know what to do more.
Maybe someone can help me out here!! ,
I like to get it running again.
Regards, John Hoek
