587,369 active members*
3,360 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Problem with variable radius fillet
Results 1 to 5 of 5
Threaded View
    Nov 2004
    Hi all
    I am pretty new at Solidworks, and have a problem with filleting the part attached. This is a flange for the chimney of a model steam engine. I need to create a variable radius fillet between the chimney and the flange surface. A constant radius is created - no problem, but when I select variable radius, I cannot create control points at each quadrant to assign radii - why?
    Kind Regards
    Craig
    Attached Files Attached Files
