588,275 active members*
6,088 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > Unfolding 3D models to flat plate for CNC cutting
Results 1 to 1 of 1
Threaded View
    May 2009
    11
    I needed to find a utility to unfold 3D models onto flat plate for CNC plasma and laser cutting. The output had to be .dwg 2D. After checking the Internet for software utilities (some were quite expensive), I decided to try using Rhino 5 to solve the problem.
    Pascal Golay, Rhino tech support, is the real author of this tutorial. I simply took his instructions and wrote them down so that the other engineers in my group could learn how to do everything in 5 easy steps.
    This tutorial shows how to build typical steel channels in 3D and then flatten them to produce cut files. It takes into account the added material required when folding steel or aluminum with a brake. It should work with multiple axes curved models .... I haven't had time to investigate the full potential of the commands used. Use it freely, send copies to your friends ..... make your life easier!
    Attached Thumbnails Attached Thumbnails Tutorial - Create CNC Cut Files in 5 Easy Steps using Rhino 5.pdf
  1. Plate vs Flat Bar?
    By kolias in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 03-14-2012, 11:47 PM
  2. Trying to locate some 41L30 flat bar or plate
    By cnctech in forum Want To Buy...Need help!
    Last Post: 12-16-2010, 06:31 PM
  3. Unfolding / flat pattern generation methods
    By Beefy in forum Uncategorised CAD Discussion
    Last Post: 06-22-2010, 10:42 PM
  4. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 06:48 AM
  5. 10mm Aluminium Plate Not Flat
    By gtrdude in forum MetalWork Discussion
    Last Post: 06-25-2006, 04:46 AM
