Hello,
I am trying to use Mach3 and a Gecko G540 to control a "Sangmutan" 2200W BLDC motor + driver. I am using the motor on a direct belt driven G0704 conversion.
The motor and driver is here:
http://www.automationtechnologiesinc...tor-and-driver
The main discussion thread is here:
http://www.cnczone.com/forums/bencht...tml#post800897
I followed this condensed guide to get an external potentiometer working and have made the appropriate connections to put the spindle in the FOR direction and Start stage.
http://www.cnczone.com/forums/attach.../432048.attach
I am trying to use a 0-5V analog signal to control the speed of the motor by using the relevant analog input pin on the BLDC motor driver board. I have verified that this functionality works by using an external potentiometer and varying a 0-5V signal to the relevant ports. I was able to control the motor across its full range of 0-6000rpm with the 0-5V input.
I now want to replicate this using my G540. I have my G540 hooked up and it correctly controls the 3 stepper motors using a DB25 parallel printer port on a Windows XP machine.
I have supplied the G540 "VFD" pins with external 5V supply, external 5V ground and then I have connected the G540 VFD output to the "Sangmutan" driver board analog input and also the respective grounds have been joined.
From this point on I am unsure what to do in relation to the Mach3 configuration settings. I have read through all of the forums and discussion posts that I could find but there is a huge amount of incorrect and contradictory information.
Mach3 Settings that I think are correct:
Spindle Pulley 1 set to 7000rpm.
Mach3 Settings I am not sure about:
  • Ports and Pins
  • Spindle Settings
  • Whether a physical on/off spindle control relay is required
  • Whether motor speed feedback in required
I would greatly appreciate any help.
Regards,
Barry
