Originally Posted by
handlewanker
Hi, I get the impression that with a slab of hardwood or aluminium 2" thick X 6" wide and 30" long you would be working on something that looks like a large flat panel.......that is, working on each of the wider flat sides top and bottom etc.
It must be realised that as soon as you get away from the centre line of the work piece the torque reaction that the cutter applies to the 4th axis head, bearings and drive are increased.
No matter how firm you hold the work piece between the tailstock and the drive there will be a deflection on each side of the work piece as at 6" wide it is 3" off centre.....this is something like stepping into a boat and having it dip down on one side from your weight.
Any deflection from the cutter forces will make any surface the cutter works on totally inaccurate.......especially in the Z axis area.
I think this would totally rule out a belt drive/timing pulley set-up mainly due to the low 1:6 reduction ratio, but also from spring in the belt drive, but the worm drive or harmonic drive types would be better on a broad faced work piece provided the backlash could be reduced to practically zero, and that was where the search for the Holy Grail was heading.
BTW.........if the work piece is a wide flat panel then I have to think that a 4th axis is not the ideal means to rotate it for surface machining as all you get is a curved surface......the Z depth will be constantly decreasing or increasing as the piece moves away from the flat plane......is that how it's meant to be?
Ian.
