Hello I am new to this site and hope I can get some help and maybe start helping others with any knowledge I might have
I have a problem with the Side Mount Tool Changer Double Arm Motor
I cannot get the motor to move the arm forward or backward in the recover mode. I have removed the motor to have it tested and the motor is working just fine. When I have the motor out I power up the machine and go into the recover mode so that I can see if the motor cam is turning and the first time I push atc fwd or atc rev the motor spins one time only. So only the first time I hit atc fwd does the cam turn. After that the motor is completely frozen and will not move at all. Any ideas what might cause this problem and what I should check to fix this issue? Is there a point on the IO board where I can check the Voltage being sent to the motor? Any help would be greatly appreciated as the machine is down and we must get it up and running soon.
The machine is a 2004 HAAS VF 2 with Side Mount Tool Changer
Thank you in advance
