I'm using the autoleveler from https://www.autoleveller.co.uk/.
Currently I'm using the Autoleveller AE (Advanced Editor)
I loaded the test pcb file that they have on their website and generated a probe file(gcode) from Autoleveller.
Then I load the probe file into Mach3 and run it.
But it just moves in a straight line in Y pauses and again moves on.
Is doesn't do any Z movement. Although there is a G31 Z-1 command in the file.
If I do a G31 Z-1 F100 through the MDI it does it correctly.
I'm now on the verge of pulling my hair out.
Is there any tutorial on how to setup Mach3 with the Autoleveller?
Does any Safe Z setting have to be turned on or off in Mach3. Because I get messages regarding the same.
Any help would be highly appreciated.
