588,212 active members*
4,230 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > newbie! need help with photoelectric sensor
Results 1 to 1 of 1
Threaded View
    hi guys this is my first post about cnc im new to this
    im looking for some help with an issue im have with wiring up a indexing sensor
    i have converted my manual lathe to cnc which ive got working fine with mach3
    ie: steeper motors
    im trying to wire up a spindle index sensor up ive made the pick up disc with the correct slot on i and mounted it to the lathe shaft
    im struggling to get the sensor to ive got the led light to flash when some thing is passed through
    it but i get nothing on mach3 screen on index pulse light
    the board is wired up to a 24v power supply and a separate one for the motor drivers
    also have a separate 5v supply for the board to work
    i have included a pic ok the sensor im trying to wire up and also a pic of the board im using
    this is the link to the data for the sensor omron ee-sx672a
    https://www.ia.omron.com/product/item/2225/
    any help will be greatly appreciated
    thanks ian
  1. Replies: 3
    Last Post: 06-26-2018, 06:56 PM
  2. Replies: 0
    Last Post: 09-02-2014, 10:50 PM
  3. Mdx-40 (with zcl-40) Y sensor Help!
    By Rastamonk77 in forum Uncategorised WoodWorking Machines
    Last Post: 02-14-2013, 10:15 PM
  4. photoelectric switch circuit
    By Malph in forum CNC Machine Related Electronics
    Last Post: 05-19-2009, 05:06 AM
