Hi guys back with another alloy cutting question, I have had success cutting with 2 and 3mm 1 and 2 flute cutters. Recently I got a new spindle with an er11 collet and have got a 4mm and 6mm cutter. With the 4mm cutter G wizard gives me a result of 24000rpm and a feed of 1536mm/min at .5mm DOC. This did not go so well not to mention I thought it was a bit high on the feed. I tried 2mm 2 flute, 13000rpm and .2 DOC in G wizardand the result was 416mm/min, this also seems way off as I have been cutting just nicely at 1000mm/min.
So
1. Have I done something wrong in G wizard?
2. I ended up with 4mm 2 flute, 24000rpm, .5mm DOC and feed 400mm/min, it cuts fine, do these numbers seem correct?
