587,594 active members*
4,057 visitors online*
Results 1 to 10 of 10
Threaded View
    Jun 2012
    153
    VFD control voltage
    I have a chinese 2kW 3 phase inverter driven spindle, bought as a pair. The VFD takes either manual speed setting or on i/p voltage.
    It provides a 10V supply which it seems is intended for a 10k pot. to provide an i/p signal for speed control
    I want to control it from software ( GRBL ) via S commands. In principal this works but the output of my circuit is very non linear.
    I have a 3V STM ARM board programmed with GRBL, I have added a GPIO port which I'm switching on an internal timer. PMW freq is 2kHz
    To protect the uP card I am going through a FOD817 opto isolator.
    It's half way there but the non-linearity above 14k rpm makes it a but useless as it is. Can anyone suggest how I should improve the cct?
    Sadly , the manufacturer does not provide any info on the nature of the i/p circuit, so it's a bit of guesswork know what to drive it with.
    TIA.
    PS I don't seem to get the graph I uploaded. Basically it is pretty linear from 0-14k ( 0-9V ) ; then it asymptotes to 10.1V. The range is good but rising too quick then flattening off.
  1. Method for Adjusting Tip Voltage for THC Control
    By garybdavis in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-23-2014, 02:57 AM
  2. Adding voltage control to a toroidal PSU
    By bakon_boy in forum CNC Machine Related Electronics
    Last Post: 10-04-2013, 02:56 AM
  3. NSK Servo voltage and control requiremnts
    By slowbob in forum Servo Motors / Drives
    Last Post: 11-12-2008, 09:17 PM
  4. Using Zener Diode for Control Voltage?
    By jevs in forum Servo Drives
    Last Post: 03-22-2005, 05:48 AM
