587,610 active members*
3,733 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Cut quality problem
Results 1 to 20 of 32
Threaded View
  1. #14
    Aug 2019
    339
    Re: Cut quality problem
    Quote Originally Posted by williamsmotower View Post
    are these settings correct?
    For the first screengrab (2Dmilling), I meant to say; try with the option "Convert Curves to Arc and Line" checked and see if you get IJK arc motions when postprocessing the program (see attached).
    If for some reason you can't get those IJK Arcs motions to output (G2/G3), and therefore limited to linear motions only (G1), then your idea of increasing the number of points onto the model itself to 10k is not a bad idea.
    How would I know if I'm getting arc output by looking at the gcode?
    (G2/G3) Arc motions
    (G0/G1) Linear motions
  1. MAX100 cut quality / nozzle build up problem
    By MrUno in forum Hypertherm Plasma
    Last Post: 08-03-2016, 08:15 AM
  2. Old problem - CO2 laser cut quality in Acrylic sheet
    By Nitrous in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-08-2015, 05:11 PM
  3. Quality Engineer/Quality manager - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:51 PM
  4. Beam quality problem ...
    By smartcut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-26-2007, 09:17 PM
