588,217 active members*
4,176 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Ball screw support bearing questions. Are $420 bearings necessary on this machine?
Results 1 to 20 of 45
Threaded View
    Feb 2005
    344
    I decided I want to get the backlash out of my 1978 Pratt & Whitney Tapemate C retrofit (Fanuc machine basically).
    It seems like the backlash is in the ball screws, but I wanted to replace the support bearings also.
    There is no info at Fanuc for the part number in the manual, so they said I need to pull the bearings to find the numbers.
    Well, I did that and they only have the generic 7204A then hand etched for the rest of the part number.
    The numbers look like
    7204A DBC9PK
    or
    7204A DBC9PX
    Not sure if that is an x or k?
    I gave this info and pics to a bearing house and I guess they sent it off to NSK.
    They came back with this part number:
    7204A5TRDUHP4Y
    When I look these up they are ABEC 7, P4 etc.
    https://www.motionindustries.com/pro...p?sku=00114980
    This seems like a lot of money for these 47mm bearings. I know bearings can be expensive, but is this reasonable for a 1978 machine? It has single nut NSK ball screws.
    I just want to make sure I am not paying too much for an over spec'd bearing. By the time I get done reconditioning two screws and replaced the support bearings I will be $2500 to $3000 in this old machine just for the XY screws and bearings (not including everything else).
    I have a lot of time and money in retrofitting it with all new AC motors, drives, full electronics, Mach4, programming time, etc etc, so I am too far into it not to get this backlash out. (~.0030 in Y and ~.0014 in X).
    I just want to make sure I need over $800 worth of bearings here.
    I am not even positive the old bearings are bad. They are old, but this machine was never in production (came from a university teaching NC programming). I have had it for 14 years myself and it was never really used during this time. I made a couple parts when I initially got it working with Mach 3, but recently I revived the interest again with getting it up on Mach 4 and upgrading the computer and some other stuff.
    Attached Thumbnails Attached Thumbnails 20191102_190426.jpg   20191103_200336.jpg
  1. Replies: 12
    Last Post: 11-03-2019, 06:04 AM
  2. Can Pillow Block Bearing KFL000 be used as END Support for ball screw?
    By sayed-anwar in forum Linear and Rotary Motion
    Last Post: 10-23-2019, 04:50 PM
  3. small diameter fixed end ball screw support bearing designs
    By CaspianCmonster in forum Linear and Rotary Motion
    Last Post: 12-10-2014, 09:49 AM
  4. Ball Screw Bearing support
    By GasserNSons in forum Fanuc
    Last Post: 09-18-2014, 05:55 AM
  5. Bmc ball screw support bearings
    By JWC in forum HURCO
    Last Post: 09-27-2008, 03:56 PM
