587,996 active members*
5,585 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Need some help, Machine not carving straight lines
Results 1 to 18 of 18
Threaded View
    I will upload some pictures to give you a better idea of the problem. I thought maybe the angle of the cutter was wrong but when I tried this test it looks like each triangle has something wrong with it. Most of the lines are bowed in and some of the corners don't look right also there was some dog bones while carving a sign earlier.
    I am tramming the spindle now and I see that it is .050 off on one side. Could this be the reason for it not carving straight lines or is it something else?
    I am hoping you guys can help.
    I don't think its a program issue this is definitely a hardware problem. I just changed the spindle out to a smaller one and also made a new and stronger bracket to hold the spindle in place. So as soon as the spindle and bracket was changed I noticed issues.
    If this isn't that right section to post in please let me know.
    Ryan
  1. Machine can't cut straight angled lines.
    By shawnmelton in forum Avid CNC
    Last Post: 03-10-2019, 04:29 AM
  2. Machine Lines when V-Carving
    By Rschaeffer83 in forum Maintenance DIY Discussion
    Last Post: 10-24-2016, 02:17 AM
  3. Machine Lines when V-Carving
    By Rschaeffer83 in forum Signmaking Topics
    Last Post: 10-24-2016, 12:21 AM
  4. Straight Lines on Curved Surface.
    By Navatek in forum CNC Tooling
    Last Post: 08-15-2011, 11:45 PM
  5. EMC G1 not producing straight lines
    By klick0 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-03-2006, 07:08 AM
