I have been working on this CNC router for the past 4 years or so and finally have it working reasonably well.
It acts as my woodworking workbench as well as a CNC router.
The wood plaque in the picture was the first real part made. The text is pocketed with a 1/16" router bit. The program for the text was 10,026 lines of code, and completed in 12.9 minutes or ~ 13 Gcode lines / sec on average.
I did the program in Fusion 360 and posted with HAAS Gcode output which then ran on the machine with a little added code to adjust for not having an ATC.
The Hardware is:
3 axis Gantry (X axis ~70" travel, Y axis ~ 49", Z axis ~ 12", but can go lower off the end of the table.) - hoping to be 4 axis some day
25mm Ball screws + Linear guides
Steel tube frame (Blanchard ground flat table frame)
Frame is 3"X 6" 1/8" wall steel tubing for the gantry. Table frame is 3"X3" tubing with extra 1/4" thickness for the linear rails.
Bed is a glued up douglas fir table with Maple edging. (3" X 37" X 104") - sacrificial MDF sheet on top.
Machine stiffness appears to be ~ 5lb / 0.0001 inches of deflection at the router tool in all three directions.
Machined aluminum for the Z axis and ball nut connections.
Yaskawa MP3300 PLC with 400W Sigma 7 servos
5:1 gear reducers on each axis (3arc min of backlash - China)
Spindle: currently just a porter cable router
Just purchased : 4.2KW 24K water cooled ATC spindle +E550VFD from china - BT30
Working on figuring out how to interface from the Yaskawa IO card to the spindle.
PLC Software:
Wrote PLC software from scratch in Motionworks IEC - Structured Text.
Separate POUs for Axis state machines, Network connectivity, and program execution.
Accepts Gcode over Ethernet (unlimited length programs)
Streams the machine execution log back to the PC
State machine operation for both Manual (Jog) and Auto (Program) modes
Implemented Gcode interpreter for HAAS Gcode
Several moves are buffered allowing for blended motion
Implemented Incremental and absolute movements for linear and circular motion using PLCopen group movements
Have not yet implemented:Helical milling, Drill cycle. On the to do list
Unit tests and functional tests implemented to exercise functionality in a parallel project
PC software: Wrote PLC software in python
Displays current position, velocity and machine status
Load and run Gcode programs
Implements Manual jog, home, and power for each axis.
Tool length offsets + Fixture offsets
Preprocesses Gcode files and adjust feed rate to ensure maximum acceleration for each axis is not exceeded, and minimum Gcode command time is not exceeded (~20 ms). This ensures smooth motion during the program for collinear movements. This effectively provides an infinite look ahead buffer.
Interface is a laptop running the PC software on the same wifi network as the CNC router.
