603,960 active members*
3,867 visitors online*
Results 1 to 20 of 301
Threaded View
millman52 Started building new 5 X 10... 01-25-2007, 03:54 AM
santiago lisboa I will follow you 02-02-2007, 03:32 PM
millman52 I am making enough CAD... 02-02-2007, 09:56 PM
millman52 I have my stepper motor sizes... 02-16-2007, 04:45 AM
txcowdog Why not build the Mechmate?... 02-16-2007, 07:18 AM
millman52 Looked at the Mechmate, As... 02-18-2007, 12:09 AM
txcowdog I understand what you mean. I... 02-18-2007, 07:46 AM
millman52 X rail mount 02-18-2007, 08:27 AM
massajamesb Looks good! Keep it going and... 02-18-2007, 10:27 AM
millman52 Rail-Beam assembly 02-18-2007, 05:17 PM
Weldtutor Good Start! 02-18-2007, 09:03 PM
millman52 That old rascal has the best... 02-19-2007, 12:04 AM
millman52 Second X Beam & rail 02-19-2007, 02:51 AM
millman52 Haven't posted in a while. I... 03-06-2007, 10:43 AM
millman52 Gantry rail 03-10-2007, 03:52 AM
millman52 Linear Rail 03-10-2007, 07:56 AM
millman52 Torch Mount 03-11-2007, 03:18 AM
millman52 More Of The Build 03-19-2007, 12:11 AM
massajamesb Lookin' good, Millman! Have... 03-19-2007, 12:22 AM
millman52 Boy that would be slicker-N- ... 03-19-2007, 01:02 AM
massajamesb Well, something to chew on... 03-19-2007, 01:11 AM
millman52 Finished Oxy THC 03-19-2007, 04:09 AM
PlasmaGuy I am enjoying seeing your... 03-20-2007, 09:13 AM
millman52 Thanks for the encouraging... 03-20-2007, 12:25 PM
millman52 Gantry Rack Gear 03-24-2007, 11:47 PM
PlasmaGuy From the photo, it looks like... 03-25-2007, 02:39 PM
millman52 These pictures are of the... 03-25-2007, 09:38 PM
millman52 Gantry Pinion bearings &... 03-25-2007, 10:00 PM
millman52 I couldn't stand the thoughts... 03-30-2007, 09:59 PM
Richard Honey Richard Honey 03-30-2007, 10:25 PM
millman52 Take a good look at the... 03-31-2007, 01:36 AM
millman52 Frame 04-04-2007, 02:08 AM
Weldtutor Great machine you are... 04-04-2007, 03:03 AM
millman52 2nd X rail truck 04-05-2007, 05:23 AM
PlasmaGuy Is the faltbar you are using... 04-05-2007, 12:55 PM
millman52 Both the round & the flat is... 04-05-2007, 10:24 PM
millman52 Mounting Gantry 04-06-2007, 07:10 AM
millman52 I'll be starting the task of... 04-07-2007, 10:38 PM
millman52 Rack Gear Drilling 04-08-2007, 05:58 AM
millman52 Rack Gear End Joint Spacing 04-08-2007, 07:25 AM
millman52 Rack gear Mounted to Strap 04-13-2007, 03:05 AM
DeviousMW What is the size of your main... 04-14-2007, 08:24 AM
millman52 2" X 6" X 3/16" 04-15-2007, 11:33 AM
millman52 Rack Mounted to X rails 04-15-2007, 09:56 PM
millman52 Floating X Drive(s) Spring... 04-17-2007, 11:01 PM
millman52 X drives mounted 04-27-2007, 03:54 AM
massajamesb they might work, or how about... 04-27-2007, 04:14 AM
Greolt KISS. :) Don't complicate... 04-27-2007, 04:24 AM
millman52 With paying work & loosing... 05-17-2007, 02:44 PM
millman52 managed to get the slat... 05-19-2007, 01:36 AM
millman52 Burning slat holders 06-14-2007, 12:06 AM
millman52 Leg mounting detail 06-15-2007, 04:54 PM
Dale Heart I did the same thing with the... 06-17-2007, 03:11 AM
millman52 Leg Leveling Adjusters 06-17-2007, 05:55 PM
ghjr Nice machine! Did you... 07-11-2007, 03:29 AM
millman52 I purchased mine from... 07-11-2007, 07:44 AM
millman52 Been a while since I posted. ... 08-09-2007, 03:02 PM
millman52 Finally, back in the mood to... 09-19-2007, 09:10 PM
millman52 Here are a couple pics of my... 09-19-2007, 11:39 PM
twjohnson13 Millman, two reasons for this... 09-24-2007, 08:31 PM
millman52 Thanks for your encouraging... 09-24-2007, 10:38 PM
DISCONNECTED You will find you really do... 09-25-2007, 02:52 AM
grinder_gary Mach simulation 10-05-2007, 09:11 PM
millman52 I have seen people rout the... 10-13-2007, 12:26 AM
lamicron I use corel for cutting in a... 09-25-2007, 01:06 PM
millman52 As I stated earlier I haven't... 09-26-2007, 12:08 AM
millman52 Last few days I have been... 10-05-2007, 06:24 PM
millman52 Updates 10-11-2007, 09:33 PM
lamicron Millman, the cable carriers... 10-12-2007, 12:40 AM
millman52 I bought mine (new) from Ebay... 10-12-2007, 11:16 AM
lamicron I' going to use rivets, and... 10-12-2007, 01:23 PM
millman52 IT's ALIVE !!!!!! 11-18-2007, 04:21 AM
Weldtutor First We Crawl 11-18-2007, 06:04 PM
millman52 A Few Updates 11-18-2007, 10:53 PM
lamicron Hi millman, why you have 3... 11-19-2007, 12:03 AM
millman52 I use 2 regulators at the ox... 11-19-2007, 06:03 AM
millman52 More progress 11-19-2007, 06:14 AM
millman52 I managed to get my steppers... 11-20-2007, 05:05 AM
millman52 Have run the table with... 11-27-2007, 10:13 PM
lamicron Hey Millman, I have my... 11-28-2007, 04:47 AM
millman52 Yes I am using mach3. I... 11-28-2007, 01:29 PM
lamicron Hi millman, I found the... 11-28-2007, 11:25 PM
millman52 Both your X & slaved A motors... 11-28-2007, 11:51 PM
lamicron Thanks, that last is the... 11-29-2007, 04:19 AM
lamicron I have problems with the... 12-01-2007, 12:54 PM
millman52 Luis, I don't remember what... 12-01-2007, 02:20 PM
lamicron Thanks Millman, i'm going to... 12-01-2007, 03:21 PM
millman52 I pulled an all nighter last... 12-01-2007, 03:53 PM
lamicron I'll check that , thanks 12-01-2007, 04:49 PM
millman52 Converted linear actuator. 12-02-2007, 03:33 AM
lamicron Ok, Millman, that worked, now... 12-04-2007, 02:45 AM
millman52 For your Y axis go to... 12-04-2007, 11:21 PM
Greolt Two points to make here. ... 12-05-2007, 01:18 AM
millman52 Greolt, Thanks loads... 12-05-2007, 01:36 AM
lamicron Thanks Greolt and Millman, I... 12-05-2007, 02:03 AM
lamicron Wich version of Mack are you... 12-05-2007, 01:19 PM
millman52 I'm using the latest version... 12-05-2007, 01:58 PM
lamicron Ok, If I install the new... 12-05-2007, 02:50 PM
millman52 You do not have to erase the... 12-05-2007, 09:52 PM
lamicron Ok, I reinstall the new... 12-06-2007, 02:18 AM
millman52 Am I correct your table is... 12-06-2007, 05:13 AM
lamicron I have also the electonics... 12-06-2007, 01:15 PM
millman52 Unless you have a 3 line... 12-06-2007, 02:51 PM
lamicron You are rigth about the 5th... 12-06-2007, 07:22 PM
millman52 I'm not sure what you have... 12-06-2007, 10:12 PM
lamicron Look where i have the g code... 12-07-2007, 04:24 AM
lamicron I think I found it, HOT... 12-07-2007, 05:12 PM
lamicron Now have the machine moving... 12-07-2007, 08:56 PM
Greolt Lamicron Microsteps are... 12-07-2007, 11:31 PM
lamicron Thanks Greg, in the current... 12-08-2007, 02:14 AM
millman52 Luis, sorry I haven't had a... 12-08-2007, 03:21 AM
lamicron Hi Millman, problem... 12-08-2007, 02:23 PM
millman52 I don't really have the Z... 12-08-2007, 03:36 PM
lamicron cable carriers 12-11-2007, 02:45 AM
eloid how are u casting these, what... 12-13-2007, 03:29 AM
millman52 I can't load a file with .tap... 12-11-2007, 01:19 PM
lamicron Hi , have a problem, dont... 12-11-2007, 06:24 PM
millman52 I haven't hooked a plasma to... 12-12-2007, 12:54 AM
lamicron Ye sI hve saved it but one of... 12-12-2007, 01:19 AM
Weldtutor Settings 12-12-2007, 02:12 AM
lamicron THANKS!!! WT< , You are not... 12-12-2007, 02:23 AM
Weldtutor Sorry, I'm not familar enough... 12-12-2007, 03:28 AM
lamicron Thanks anyway, Luis 12-12-2007, 04:14 AM
millman52 Luis, I might be a bit... 12-12-2007, 02:53 PM
millman52 First full sheet processed 12-13-2007, 01:33 AM
Weldtutor All the work has paid off! ... 12-13-2007, 03:12 AM
lamicron I'm using polystyrene, 3 mm,... 12-13-2007, 04:02 AM
lamicron Ok, now have the conection... 12-13-2007, 04:28 AM
millman52 I had to juggle my steps per... 12-13-2007, 01:27 PM
lamicron Good to know i'm going ok for... 12-13-2007, 01:33 PM
lamicron This is my first plasma... 12-14-2007, 02:37 AM
lamicron Machine cutting!!!! 12-15-2007, 12:42 PM
lamicron Now I have some questions, if... 12-15-2007, 12:48 PM
millman52 Nesting is done in Sheetcam. ... 12-16-2007, 01:23 AM
lamicron Machine cutting!!!! 12-15-2007, 01:00 PM
millman52 Feel really good to watch... 12-16-2007, 05:18 AM
lamicron Ok, that helps , and when you... 12-16-2007, 01:57 AM
millman52 So what you have is a pre... 12-16-2007, 03:20 AM
lamicron Thanks, hey are you having... 12-16-2007, 01:36 PM
millman52 Yes I actually have one of... 12-16-2007, 02:30 PM
lamicron That problem you had , the... 12-16-2007, 05:17 PM
lamicron Tomorrow i'll try to cut with... 12-16-2007, 05:30 PM
millman52 Just bring the water to, or... 12-16-2007, 05:57 PM
millman52 http://www.jlindustrial.com/CG... 12-16-2007, 05:36 PM
millman52 400 IPM 12-16-2007, 11:36 PM
lamicron Feliz navidad !! To all of ... 12-22-2007, 08:44 PM
millman52 Just wondering if others... 12-29-2007, 02:41 PM
kermit582 plans 12-29-2007, 06:53 PM
lamicron Cable carrier 01-22-2008, 05:17 AM
millman52 Great looking job!! I... 01-22-2008, 01:22 PM
lamicron There is no nut there, When i... 01-22-2008, 02:05 PM
millman52 From looking at the picture.... 01-22-2008, 11:41 PM
lamicron Will try it, thanks Luis 01-23-2008, 12:38 AM
millman52 I've been buisy for a while... 02-03-2008, 04:37 PM
scott wiggins Any progress on the drawings?... 02-03-2008, 08:45 PM
millman52 Hi Scott, Since the first... 02-03-2008, 09:38 PM
scott wiggins Thank you for the effort. ... 02-04-2008, 12:52 AM
millman52 Table in action 02-17-2008, 04:53 AM
Fab_27 I would be interested in more... 02-17-2008, 08:48 PM
mcArch Millman, I just went through... 03-13-2008, 03:49 PM
millman52 There isn't any pipe. There... 03-16-2008, 06:33 PM
mcArch Well, I thought it ought to... 03-17-2008, 03:15 AM
millman52 I couldn't be more pleased... 03-17-2008, 03:13 PM
millman52 I'm glad I built my table to... 05-17-2008, 02:10 AM
mcArch Nice Millman! One should... 05-17-2008, 03:24 AM
millman52 Mike, I am using the... 05-17-2008, 11:31 AM
Torchhead The MP1000C series we... 05-17-2008, 05:48 PM
Big John T EMC2 supports 9 axis and is... 05-19-2008, 03:45 PM
Torchhead EMC is a software controller.... 05-19-2008, 05:46 PM
Big John T The $160 wasn't even a... 05-19-2008, 08:00 PM
millman52 I went with Mach, Sheetcam, &... 05-23-2008, 09:34 PM
Big John T Have you done any cutting of... 05-27-2008, 02:42 PM
millman52 John, Thus far I have used... 05-27-2008, 10:33 PM
lamicron Hi Millman, I have some... 05-23-2008, 10:10 PM
millman52 Luis, I don't have any... 05-27-2008, 11:30 PM
MonoNeuron Just to chime in about the 6... 07-25-2008, 04:50 PM
Torchhead The most common use for five... 07-25-2008, 05:39 PM
MonoNeuron I re read my post just after... 07-26-2008, 12:42 AM
lamicron Hi Millman, I´m looking for... 10-01-2008, 01:32 PM
millman52 First a note of caution. ... 10-01-2008, 10:16 PM
millman52 These have 24 V coils. but... 10-01-2008, 10:33 PM
lamicron Thanks for the warning, (... 10-02-2008, 02:59 AM
millman52 Just posted those for an... 10-02-2008, 12:58 PM
chopper14 Millman hi there what corel... 10-07-2008, 09:23 AM
millman52 I have Corel 12 but don't... 10-07-2008, 12:29 PM
lamicron Hi Millman , need your help,... 01-31-2009, 05:04 AM
millman52 (1) PREHEAT TIME: I honestly... 01-31-2009, 02:08 PM
lamicron I also have to hit gotoz to... 01-31-2009, 04:29 PM
millman52 Preheat time should be the... 01-31-2009, 06:06 PM
lamicron looking at your videos ,... 02-01-2009, 03:52 AM
millman52 The program raises the torch... 02-01-2009, 06:54 PM
lamicron I changed a parameter in... 02-07-2009, 05:49 AM
millman52 Wear of Linear rail & bearing... 03-01-2009, 12:10 AM
asuratman Hi Millman52, How do you... 03-01-2009, 10:16 PM
millman52 You set up your torch tip in... 03-01-2009, 10:35 PM
MonoNeuron Hey Milly, I too have had... 03-02-2009, 12:46 AM
millman52 Regardless what you do even... 03-02-2009, 03:57 AM
Dustin407 mono/millman 03-03-2009, 07:47 PM
semi-lucid millman In another thread... 03-05-2009, 03:17 AM
millman52 First thanks for the reply. I... 03-05-2009, 10:27 PM
millman52 Yipee!!! Finally found the... 03-06-2009, 12:18 AM
semi-lucid That leaves me wondering what... 03-05-2009, 11:46 PM
millman52 The roller carrage body is... 03-06-2009, 12:54 AM
semi-lucid Thanks for the link.... 03-06-2009, 01:56 AM
millman52 You are probably right in... 03-06-2009, 11:51 PM
semi-lucid I agree with your point about... 03-07-2009, 02:47 AM
millman52 I know looking at the... 03-07-2009, 09:49 PM
millman52 Pricing of Alum linear rail 03-15-2009, 12:13 AM
semi-lucid So, when you contacted Franke... 03-15-2009, 02:43 PM
millman52 Franke has a distributor in... 03-15-2009, 05:16 PM
millman52 Final Pricing 03-19-2009, 10:57 PM
MonoNeuron http://video.designworldonline... 03-19-2009, 11:31 PM
millman52 Interesting you should bring... 03-20-2009, 11:58 PM
MonoNeuron "Expletive". I can't believe... 03-21-2009, 12:50 AM
millman52 Although I didn't check into... 03-22-2009, 12:51 AM
plain ol Bill Millman look into purchasing... 03-22-2009, 02:54 AM
MonoNeuron I have ground chrome plated... 03-22-2009, 08:48 AM
MonoNeuron One more thing with CRS flat... 03-22-2009, 08:53 AM
millman52 I have already ordered the... 03-23-2009, 12:01 AM
serhey778 What brand of plasma cutter... 03-24-2009, 01:24 AM
millman52 I have www.CandCNC.com MP1000... 03-24-2009, 11:27 AM
asuratman Hello, Good day. Sorry, my... 03-22-2009, 04:03 PM
millman52 I am using a stepper system. ... 03-24-2009, 11:40 AM
asuratman Hi millman52, Thanks for... 03-24-2009, 12:41 PM
millman52 I have receieved the new rail... 04-05-2009, 04:21 PM
Shapenfab Good lookin casette, I'll bet... 04-17-2009, 03:30 AM
millman52 Simple upgrade***Major... 05-02-2009, 04:26 AM
millman52 Managed to get a bit more... 05-03-2009, 07:03 AM
lamicron I have the drawings in corel,... 05-04-2009, 04:18 AM
Dustin407 I have autocad 2007 if you... 05-04-2009, 06:00 AM
Dustin407 I see you cut all three sides... 05-04-2009, 06:05 AM
lamicron Sorry for the delay, tomorrow... 05-05-2009, 02:10 AM
lamicron I used 1/8" HR plate to make... 05-05-2009, 02:23 AM
millman52 Purchased a new HT1250 today.... 05-05-2009, 09:18 PM
Dustin407 millman, hows the new z-axis... 05-15-2009, 09:15 PM
millman52 About all I have managed to... 05-16-2009, 03:11 AM
Dustin407 Millman, thanks for the... 05-20-2009, 05:14 AM
millman52 Thanx for the favorable... 05-20-2009, 12:50 PM
Weldtutor This Might Help! 05-20-2009, 03:48 PM
millman52 River bank He** I'll be on... 05-20-2009, 10:56 PM
MonoNeuron I'm jealous. I purchased my... 05-20-2009, 04:20 PM
millman52 Funny thing on the HT 1250... 05-20-2009, 10:44 PM
MonoNeuron Yes, I got ripped off with... 05-25-2009, 02:28 PM
millman52 Mono, One of my employees... 05-25-2009, 05:24 PM
MonoNeuron That's great about the parts... 05-28-2009, 01:00 PM
millman52 Mono, The dry lube that Ron... 05-28-2009, 02:59 PM
millman52 :violin:Mono, The Dry lube... 06-10-2009, 11:57 PM
lamicron Hi Millman, i have problems... 06-17-2009, 04:31 AM
millman52 Yes I chase it manually. ... 06-17-2009, 04:41 AM
Dustin407 Hey millman, Just droppin... 06-17-2009, 07:47 AM
millman52 I have my Plasma Z backplate... 06-17-2009, 01:04 PM
millman52 Few more pics of some work on... 06-24-2009, 11:54 PM
MonoNeuron Hi Millman, Thanks for the... 06-25-2009, 01:45 AM
MonoNeuron Hey Milly, Just a thought.... 08-17-2009, 03:23 AM
millman52 Except for the machine torch... 08-17-2009, 01:37 PM
lamicron Millman, Could you send me... 10-01-2009, 08:13 PM
lamicron Other thing I want to do is... 10-01-2009, 08:24 PM
millman52 Luis, Did you get this... 02-06-2010, 07:31 AM
millman52 I finally have resumed a bit... 02-06-2010, 07:34 AM
asuratman Hi Lamicron, Does your... 02-06-2010, 09:04 AM
millman52 assuratman, The digital... 02-06-2010, 12:49 PM
millman52 Gantry Upgrade Progress 02-07-2010, 12:35 AM
millman52 Managed to install pull apart... 03-06-2010, 02:07 PM
Torchhead You just introduced another... 03-06-2010, 06:11 PM
millman52 Thanks Tom, It's not about... 03-06-2010, 09:14 PM
ffelini Hello Millman! I just saw... 03-11-2010, 11:20 PM
millman52 The machine had been running... 03-11-2010, 11:50 PM
ffelini Thanks for the advise Millman... 03-13-2010, 03:05 AM
millman52 The reason for 4 Axis is so... 03-13-2010, 06:09 AM
anxpert Bearing Suggestions 03-13-2010, 05:59 PM
millman52 If you are going to use a... 03-13-2010, 08:31 PM
ffelini Anxpert: As soon as I have my... 03-13-2010, 06:57 PM
asuratman Hi anxpert, You better make... 03-14-2010, 12:47 AM
millman52 There is more on an upgrade... 03-14-2010, 03:48 AM
Torchhead The most successful Multi-use... 03-14-2010, 06:48 PM
DanOSB im the guy who owns that... 03-15-2010, 06:55 AM
Torchhead Oh, Dan, thats' YOU ?? Was... 03-15-2010, 05:02 PM
anxpert Router / Plasma 03-17-2010, 06:03 AM
millman52 LATEST UPDATE 03-20-2010, 03:35 AM
millman52 Finally got around to... 03-28-2010, 05:08 AM
millman52 Here is a few pictures of the... 03-28-2010, 08:46 AM
Dustin407 Nice Job!!!! 04-03-2010, 09:04 PM
millman52 I had the engineering... 04-04-2010, 03:19 PM
jjellingson Have a question about gantry... 12-11-2010, 02:49 AM
millman52 Yes, As long as there isn't... 12-20-2010, 03:39 AM
millman52 Thanks Dustin, I did weigh... 04-03-2010, 10:58 PM
WSS Swamped w/work! 12-20-2010, 06:27 AM
millman52 Well time for yet another... 02-05-2012, 05:50 PM
MonoNeuron I remember years ago you said... 02-06-2012, 04:16 AM
millman52 I see nothing wrong with... 02-10-2012, 03:10 AM
millman52 Re: Started building new 5 X... 01-09-2016, 01:19 AM
    Feb 2006
    1260
    Started building new 5 X 10 table today
    Started on some of the smaller parts I have already created CAD drawings of. I don't have everything I need gathered up for the build but though I'd try & get a few things out of the way.
    Pictured below is a bearing truck I am going to use on the X axis. Have more to go on it but at least it's a start.
    The bearings I used for this are high precision double row left over from another job.
    If it works.....Don't fix it!
  1. Started building joes 06
    By troach in forum Joes CNC Model 2006
    Last Post: 04-13-2009, 07:51 PM
  2. Get started today!
    By jonesmoo in forum Employment Opportunity
    Last Post: 02-20-2009, 02:46 AM
  3. Started building at last!
    By The Wizard in forum CNC Wood Router Project Log
    Last Post: 09-05-2007, 09:16 AM
  4. just started today
    By EMCLLC in forum Commercial CNC Wood Routers
    Last Post: 01-22-2007, 10:34 PM
  5. Started first CNC today
    By TopSpin80 in forum DIY CNC Router Table Machines
    Last Post: 02-03-2004, 03:01 PM
