588,043 active members*
4,219 visitors online*
Results 1 to 9 of 9
Threaded View
    Oct 2021
    6
    Concrete with 8020
    Hello all, I am slowly building a CNC Mill about 12x10x5" in size. I would like to use aluminum extrusions as they offer me the most flexibility because I intend to modify the build as I go, and change out linear rails, spindle, and ball screws later. I want more rigidity though so I would like to fill the frame with concrete where I can. I don't want o fork over the money for epoxy/sand/granite that's why I'd like to use concrete. Problem is that concrete reacts with aluminum, so I was wondering if anyone has tried coating their extrusions in clearcoat spray, thin epoxy layer, or something else to protect the concrete from the extrusions? Here's the rough sketch I have, but I am working on a more professional drawing as I get in parts and measure them correctly.
    The blue is concrete and the gray is aluminum, I used 4" PVC pipe as a filler to reduce the concrete needed without reducing damping/strength much.
  1. attaching 8020 to existing 8020
    By greenene in forum T-Slot CNC building
    Last Post: 11-01-2014, 01:26 PM
  2. Concrete Stamp....
    By AussieGecko in forum Uncategorised MetalWorking Machines
    Last Post: 08-15-2013, 01:25 PM
  3. Replies: 0
    Last Post: 11-28-2012, 06:39 PM
  4. Polymer Concrete
    By ericdwilso in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2009, 07:00 PM
  5. Concrete milling
    By Tompie in forum Community Club House
    Last Post: 09-20-2005, 06:57 AM
