587,691 active members*
3,695 visitors online*
Results 1 to 8 of 8
Threaded View
    Jul 2023
    5
    Path doesn't make sense.
    The gcode is intended to finish the path on the X-axis (Y0) on the right, but the path does not end where it should.
    Can anyone see where the problem is?
    (1)
    (C8 CN trim) ;0.125 ;Max Tool Dia 0.125
    (Set origin to socket axis, just outside edge of Al frame.)
    (Move tool to X0 Y5)
    G90 ;Absolute co-ordinates
    F100 ;Set cutting speed
    G0 X-3.86 Y1 ;Go quickly to 1 mm from job
    G1 X-3.86 Y0 ;Go more slowly to the start of cut
    G2 X-1.93 Y-0.8 I0 J-2.73 ;Cut a CW arc 2.73mm radius
    G3 X1.93 Y-0.8 I1.93 J2.73 ;Cut an ACW arc 2.73mm radius
    G2 X3.86 Y0 I1.93 J-2.73 ;Cut a CW arc 2.73mm radius
    G0 X0 Y5 ;Go quickly to 5 mm from job
    M30 ;End routine
  1. Wiring adapter for 220v 50w laser doesn’t make sense
    By MadGumby in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-11-2021, 07:06 PM
  2. Does it make sense?
    By vinybinder in forum Mechanical Calculations/Engineering Design
    Last Post: 06-24-2010, 05:42 PM
  3. Mirror Adjustment - Does this make sense?
    By LuAn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-07-2009, 04:07 PM
  4. Finally, Soft Jaws that Make Sense
    By Team Pierson in forum News Announcements
    Last Post: 04-29-2008, 02:24 AM
  5. Does this make sense??
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 12-29-2005, 07:28 AM
