I'm offering up a version of our tool change macro that we use to make tool changes easier and less code intensive in programs. Note this also makes MDI tool changes MUCH easier. This will activate the tool length offset and work offset G54 as well. This requires macros to use.
I'd appreciate any comments or suggestions for improving this.
And a disclaimer: Check the G and M codes against what your machine uses!
Usage:
T12
M98 P9006 (or just and M6 if you register the program, see below)
Yep that is all it takes to get T12 called to the spindle, with the tool length active.
You may replace the M98 P9006 with a simple M6 if you register program O9006 as M6 This may vary some for different controls, on our machine we have to set parameter 6046 = 6
parameter 6041 matches O9001
6042 matches O9002
Ect.
What ever number is assigned to the 604x is the M code that runs the 900x program
Code:
O9006 (TOOL CHANGE)
G80
M9
G91G30Z0M5
G30X0Y0M15
IF[#[2000+#4120]LE11.0]GOTO10
#3000=97 (,YIKES, TOOL LENGTH IS TOO LONG)
N0010
G90
T#4320M6
G53 (SUPPRESS MULTI-BUFFER)
IF[#4320EQ0]GOTO9999
POPEN
DPRNT [TIMES@#3011[80]@#3012[60]@P#120[40]@T#4120[20]]
PCLOS
IF[#[2000+#4120]GE1.0]GOTO20
#3000=98 (,YIKES, TOOL LENGTH IS TOO SHORT)
N0020
IF[#[2200+#4120]LT1.0]GOTO30
#3000=99 (,YIKES, TOOL WEAR IS TOO LARGE)
N0030
G90G0G43G54Z[24.99-[#[2000+#4120]+#[2200+#4120]]]H#4120
IF[#4320NE#500]GOTO50
M0
M99
N0050
M1
N9999
M99
Now for the breakdown of the code
O9006 (TOOL CHANGE)
G80
M9
G91G30Z0M5
G30X0Y0M15
End previous activities and go to tool change position. Make sure automatic cycles are canceled and coolant is off, stop and orient the spindle.
N0010
This is a quick check that the tool isn't too long for the machine/tool change, and will stop with error 97 and ",YIKES, TOOL LENGTH IS TOO LONG" as the message.
G90
T#4320M6
The actual tool change. this machine uses the T# on the same line as the M6 not all will. #4320 recalls the last T# used previously
If T0 is called exit without activating any tool length ect.
POPEN
PCLOS
Outputs on the com port a line with the date and time, program number, and tool number separated by the @ symbol. I couldn't figure out how to output a comma or tab...
N0020
More tool length and length wear checks to make sure something stupid wasn't put in the offset table. This will also catch a missing offset
N0030
G90 G0 G43 G54 Z[24.99-[#[2000+#4120]+#[2200+#4120]]]H#4120
Here we activate the tool offset. Home position is at Z25.0 This calculates the tool length and moves to Z24.99 (0.010 move) The move is required to activate the tool offset.
M0
M99
A number in macro variable 500 will cause the program to pause after changing to that tool number. cycle start will continue normal operation.
N0050
M1
N9999
M99
And finally turning on optional stop stops after any/all tool changes.
Here is a simple version with very little of the fancy stuff
Code:
O9006 (TOOL CHANGE)
G80
M9
G91G30Z0M5
G30X0Y0M15
T#4320M6
M99
