588,600 active members*
11,778 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Milling flats on the side of round stock
Results 1 to 19 of 19
Threaded View
    Jun 2006
    3063
    I've got a round part that was turned on a lathe and am trying to figure out how to use SprutCAM to generate a toolpath to mill two flats vertically on opposing sides of the part.
    The best I've come up with is a 2D contouring operation which is attached as a zip of the STC file but it also side mills around the periphery of the part.
    The jpeg shows the flats to which I'd like to limit the milling operation, but I can't figure out a way to do it.
    Can anybody suggest a solution?
    Thanks, Mike
    Attached Files Attached Files
  1. how does artcam do round stock, legs, etc?
    By lesd in forum ArtCam Pro
    Last Post: 10-25-2009, 03:48 AM
  2. 1018 Round Stock in SE PA
    By buckkillr8 in forum Employment Opportunity
    Last Post: 08-06-2007, 08:55 PM
  3. Macro for milling round bar
    By sencinia in forum MetalWork Discussion
    Last Post: 03-31-2007, 04:58 PM
  4. Milling Flats
    By ajl6549 in forum Fanuc
    Last Post: 11-03-2006, 07:36 PM
  5. RFQ for 120QTY 5/8" Round Stock Standoffs 6061 Aluminum
    By mpstech in forum Employment Opportunity
    Last Post: 09-20-2006, 09:02 PM
