588,684 active members*
5,833 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Poor quality and Wavy Plasma cuts (Pictures)
Results 1 to 20 of 24
Threaded View
    Hi
    I have had my homebuilt Plasma up and running for a few days now, and I am trying to get to grips with all the different cutting parameters.
    I have a Hypertherm 1000 with fresh Finecut consumables and it is using a Campbells THC300 Torch Height Controller.
    I definitely have clean air, because by luck I did manage to produce a good cut once......but in my excitement I did'nt note the settings....DOH!
    Two problems I am seeing a lot are 'Wavy' cuts and not great cut quality (See Pictures)
    The material is 16swg 304 Stainless Steel.
    I ran a load of test parts to find the best cutting parameters for the material as follows.
    Internal Holes
    40amp 47.25" (1200mm) per min at a cut height of 0.25mm
    Outside Profile
    40amp 138" (3500mm) per min at a cut height of 0.25mm
    I am using a homebuilt Water Table, and have the water about 1/2" below the surface of the material.
    Would cutting with Nitrogen improve the cut quality, and if so by how much?
    Any ideas would be much appreciated.
    Andy
    Attached Thumbnails Attached Thumbnails Plasma 1.jpg   Plasma 2.jpg   Plasma 3.jpg
  1. tri-power poor quality
    By digitalmdj in forum Shopmaster/Shoptask
    Last Post: 12-02-2007, 01:45 AM
  2. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  3. Rapid speed between cuts(plasma)
    By C.Michael in forum SheetCam
    Last Post: 11-18-2007, 08:03 AM
  4. Poor cuts, what's going on?
    By cn00728 in forum MetalWork Discussion
    Last Post: 10-01-2007, 10:43 PM
  5. Pictures of my first cuts with my Torchmate 1
    By blackhollowmfg in forum Torchmate
    Last Post: 03-19-2007, 06:05 PM
