Originally Posted by
ckelloug
sigma John,
Sorry not to key on the DOE (not Dept. of Energy) trial thing. I've been busy trying to solve a riduculously annoying but simple software problem in the paying portion of my life for the last week or so.
In general, I would consider the aggregate problem to be solved. Given any mixture of aggregate, I can say within less than 3% what the packing density Phi will be after taking a Beta measurement on each component. (I'm using estimated beta values right now and thus my results are only relative to one another right now). The French Researcher, de Larrard, whose models I have implemented spent about 10 years validating them with data and has published many papers and the book I am working from. I have shown that I can duplicate the numbers published in his book.
Given that the aggregate packing density Phi can be calculated to within 3% for the model, My engineering judgment tells me the DOE experiment design doesn't need to account for individual aggregate types but should instead specify Phi values. Phi goes from 0 percent (all epoxy) by volume to about 92% (8% epoxy) by volume.
It is known from the rule of mixtures model that modulus follows a uniformly increasing nonlinear curve with percentage of aggregate. It is also known that eventually there is a point where the modulus becomes zero with increasing aggregate content due to insufficient epoxy to bind the material.
The minimum amount required to fill all of the empty space in the solid is 1-Phi. Any less than that and the mixture doesn't contain enough epoxy to hold itself together. More epoxy than 1-Phi that causes the particles to be fully encapsulated by epoxy in model terms.
So, I would say the first unknown is what the optimal amount of epoxy for maximum modulus is. Of course this assumes that all mixtures with the same Phi value are equally good for modulus. This assumption is true according to the rule of mixtures but there could be effects related to the quality and type of aggregate that cause fractures which affect the result.
Here is the summary of factors,likely effects on modulus, and range is as below:
Packing Density of Particles: positive linear: 0----92% by volume aggregate
Epoxy volume percentage in composite: negative linear: (100% - Phi)----50% by volume aggregate
Titanate Concentration: concave down parabolic: 0----1% by weight aggregate
Silane Concentration: concave down parabolic: 0----5% by weight aggregate
Cobalt Acetyl Acetonate Concentration: positive linear: 0----1% by weight epoxy
Epoxy to Hardener Mix Ratio: concave Down Parabolic: 2.1-----2.5 w/w for 37-127/37-606
Well Dispersed Nanomaterial Concentration: positive linear: 0----10% by weight epoxy
Once the gross problems like bad choice of hardener etc have been worked out, a DOE trial of the above factors would be a good way of getting the optimal material.
Regards all,
Cameron
