603,936 active members*
2,174 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > 600mm Box bend brake (Finger Brake, pan Brake)
Results 1 to 20 of 36
Threaded View
RotarySMP 600mm Box bend brake (Finger... 04-18-2008, 09:08 PM
RotarySMP I started my build by... 04-18-2008, 09:16 PM
RotarySMP The steel I ordered came to... 04-18-2008, 09:21 PM
RotarySMP And these will be part of the... 04-18-2008, 09:24 PM
RotarySMP Continued work on these... 04-19-2008, 09:08 PM
RotarySMP Busy week with trips to Milan... 04-26-2008, 09:54 PM
RotarySMP Finished cutting out the... 04-27-2008, 08:56 PM
RotarySMP Made an arbor for some old... 05-02-2008, 04:30 PM
RotarySMP Been ages since I posted an... 03-29-2009, 05:41 PM
RotarySMP To cut out the side pieces, I... 03-29-2009, 05:49 PM
RotarySMP Got a good session in on... 04-06-2009, 08:31 PM
acondit Mark, It looks like you... 04-25-2009, 05:20 PM
RotarySMP Thanks Alan. Not really,... 04-30-2009, 07:08 PM
acondit Well, I never get... 05-01-2009, 03:43 AM
Kipper Brenda the Bender? I've had... 04-30-2009, 08:24 PM
RotarySMP I did a bit more work on... 10-03-2009, 04:53 PM
RotarySMP Finally got a boring head for... 11-01-2009, 12:24 AM
RotarySMP Made the feet for the bender... 12-28-2009, 03:53 PM
RotarySMP It's been cold here, and I... 02-22-2010, 10:30 PM
Eling I have started building the... 09-05-2010, 11:57 PM
RotarySMP Hi Eling, Sorry my... 09-06-2010, 04:56 PM
RotarySMP Re: 600mm Box bend brake... 05-17-2014, 08:15 PM
RotarySMP Re: 600mm Box bend brake... 11-16-2014, 07:13 PM
huntnfish Re: 600mm Box bend brake... 10-30-2015, 08:32 PM
RotarySMP Re: 600mm Box bend brake... 02-01-2015, 10:08 PM
chathorne Re: 600mm Box bend brake... 04-29-2015, 07:03 PM
RotarySMP Re: 600mm Box bend brake... 05-03-2015, 07:04 PM
chathorne Re: 600mm Box bend brake... 05-05-2015, 05:55 PM
Bent Re: 600mm Box bend brake... 05-05-2015, 06:12 PM
sudipta Cannot get the pdf! 06-26-2015, 12:21 PM
elbannan Re: 600mm Box bend brake... 05-09-2015, 02:54 PM
RotarySMP Re: 600mm Box bend brake... 07-22-2015, 10:00 AM
whiskeymike Re: 600mm Box bend brake... 08-02-2015, 05:32 AM
zaneiel Re: 600mm Box bend brake... 08-10-2015, 01:47 AM
RotarySMP Re: 600mm Box bend brake... 10-31-2015, 03:24 PM
rocketflier Re: 600mm Box bend brake... 11-01-2015, 10:24 AM
    Mar 2004
    1306
    A guy Simco on an Australian woodworking site has posted a great set of plans, with photos how to build a 600mm finger brake for bending sheet metal.
    http://www.woodworkforums.ubeaut.com...ad.php?t=45792
    He has graciously donated this design to the online community.
    As I have a sheet metal homebuilt aircraft project, I have been looking for a good design for a small brake, but until Simco's design, all the ones I had seen were either very primitive clamp an angle iron to bench type things, or Larry McFarlands very large, very tasty 8 ft brake, which I simply don't have space for.
    http://www.macsmachine.com/
    The thing I really like about Simco's design is that it has both set back and apron height adjustment, allowing you to control the bend radius, and it is a box brake, so you can remove and adjust the clamping fingers to make boxes and other complex shapes.
    I have attached photos from the original forum, showing Simco's original brake, and one by a guys called Rod.
    Attached Thumbnails Attached Thumbnails Folder.jpg   folder_front.jpg   folder_side.jpg
    Regards,
    Mark
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. I need a brake.
    By herring_fish in forum Wooden Clocks
    Last Post: 02-08-2012, 07:31 PM
  3. How do you make a narrow bend on a brake ?
    By flyinwilly in forum Uncategorised MetalWorking Machines
    Last Post: 07-31-2011, 09:58 PM
  4. brake
    By rotsenmendoza in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2011, 11:39 PM
  5. Need a box and pan brake
    By J-Mccoin 2009 in forum Want To Buy...Need help!
    Last Post: 12-11-2009, 10:10 PM
