So I'm make some aluminum shift knobs that I sanded using 600 grit and then finished with a scotchbrite pad. Finish came out excellent. Nice satin finish. I went ahead and clear anodized them and got some mixed results. All the parts got a little darker, which was expected. However some of the parts had what looked like was some dark pitting. It's not really that bad, but because I made them, I'm looking at these pretty closely. The anodizing worked well otherwise. Even tried a couple dye colors and worked great. Pretty simple process. What I'm thinking is that they were anodyzed too long or that I have the wrong ratio of sulfuric acid in the solution, or that I have the wrong current/voltage. Anyone have any quick things to look into? I'll try to get some pics up for everyone to see. Also, any other ways to finish the scotchbrighted aluminum other than an anodize. Would be great if there were a magic clearcoat that stuck to the aluminum. I think the anodizing is almost overkill for the shift knobs. Any thoughts/suggestions? Thanks for the help.
Rob
