587,968 active members*
3,338 visitors online*
Results 1 to 5 of 5
Threaded View
    Jul 2009
    Smile How to modify Fitting
    I just joined this forum and I don't have a whole lot of machining experience so I'm looking for some good'ol practical advice.
    I am modifying the fuel cross-over line from my VW van because the nylon fittings are breaking every few years. These little pieces of plastic end up costing $64+ for a replacement and I'm done shelling out that kind of cash for plastic that doesn't last. So I am going to a brass fitting but I need to modify it slightly.
    The plastic fitting has a 0.4" long shoulder which is 0.5" in diameter and I need to recreate that on the barbed brass fitting. See pic.
    What would be the easiest and most cost effective way to achieve this? Would I use a lathe or a mill?
    My concern if I use a lathe is how to fixture the part because it wouldn't be balanced.
    Thanks for your help.
  1. Modify STL in SW
    By DIFF OVER in forum Solidworks
    Last Post: 03-11-2009, 01:54 AM
  2. 31i-A5 which post to modify
    By jrobson in forum Fanuc
    Last Post: 02-27-2008, 12:34 PM
  3. how can i modify the post?
    By ahmedsamy_81 in forum Post Processors for MC
    Last Post: 07-16-2006, 08:25 PM
  4. modify drill macros
    By Karl_T in forum CamSoft Products
    Last Post: 11-18-2005, 05:10 PM
  5. Is there a way to modify LIGHT?
    By murphy625 in forum CamSoft Products
    Last Post: 04-18-2005, 09:19 PM
