588,390 active members*
5,712 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > help wiring in MPG handheld pendant to work with mach3
Results 1 to 20 of 32
Threaded View
    Oct 2006
    100
    I have just bought an ISMM2080 handheld jog pendant and want to wire it in to work with mach3 on a cnc router.
    I have purchased a second parallel port for my computer and a 25 pin solder port so I can connect all the wires. I am hoping someone has wired one of these before as I dont want to damage it by my lack of electrical know how.
    On the wiring diagram there seems to be several choices for wires number 3 and 4 and 9 and 10. I think I ignore purple and purple/black for line driver? and pink and pink/black as I only need x,y,z?
    What I need to know is assuming I have the above bit correct do the numbers on the wiring diagram follow the port designations so I only use pins 1-17?
    Here is the link for the wiring diagram
    http://www.slidesandballscrews.com/p...68%20Range.jpg
    As well as the coloured wires there is also a wire with no sheathing on, just a bare wire which has been solder prepped from the factory, where does this go?
    Thanks for any help.
  1. Mach3 ModIO Handheld Pendant
    By phomann in forum Mach Software (ArtSoft software)
    Last Post: 10-14-2013, 04:01 PM
  2. Looking for Handheld pendant
    By wickedboysap in forum Multicam Machines
    Last Post: 05-03-2011, 05:51 PM
  3. New handheld pendant for Mach3...
    By florins in forum Mach Software (ArtSoft software)
    Last Post: 11-16-2010, 04:53 PM
  4. MPG-0031 Handheld Pendant
    By Wm McNett in forum Fadal
    Last Post: 09-21-2009, 04:31 AM
  5. Micronor MR175 Handheld Pendant
    By Wm McNett in forum CNC Machine Related Electronics
    Last Post: 05-09-2008, 03:59 AM
