587,997 active members*
2,311 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Is it possible? (G540 spindle control)
Results 1 to 7 of 7
Threaded View
    Nov 2007
    980
    I'd like to inquire about a possible speed controller for my Taig Lathe CNC I've built. I have no speed control through Mach 3 but would like to if possible. I'm using the MC 60 Treadmill controller with the Bosch Treadmill motor and I'm including the wiring diagram that was furbished with the controller. The only problem I'm seeing trying to set this up is the fact that the MC60 controller has to start at 0 rpms and then be turned up to the desried speed, it can not start up at any desired speed that I would like it to.
    Is there a way that I can connect to Mach 3 to control something like this or should I be looking for a completely different motor/controller setup? If I am able, can someone help with the wiring from the controller to the 540?
    I'm including a couple of pics of the lathe itself.
    Thanks for your time.
    Dave
    Attached Thumbnails Attached Thumbnails MC60TredmillController.jpg   TaigLatheCNC2.jpg   GeckoUpdate2.jpg
    Dave->..
  1. Has Anyone used G540 to control spindle speed on the X2?
    By Waldermac in forum Benchtop Machines
    Last Post: 02-08-2018, 03:46 PM
  2. Spindle Control Through G540
    By john1285 in forum Gecko Drives
    Last Post: 09-30-2009, 04:26 PM
  3. G540 Spindle speed output voltage problem
    By georgef8 in forum Gecko Drives
    Last Post: 09-22-2009, 04:18 PM
  4. Gecko G540 and Coolant Control Relay
    By MrAR15 in forum Taig Mills / Lathes
    Last Post: 07-10-2009, 03:01 PM
  5. Geckodrive G540 Four Axis Control Bulk Pricing
    By CoAMarcus in forum News Announcements
    Last Post: 01-24-2009, 03:13 AM
