588,621 active members*
5,586 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Rewiring Transformer for 230V Input
Threaded View
    Jan 2006
    2985
    I recently bought a new lathe and I am working on getting it running. The DC spindle drive requires 460V 3 phase. I only have 230V 3 phase. The lathe has a transformer in it which is currently setup as an isolation transformer. 460 in and 460 out. The transformer is constructed from three separate transformers which are wired together. The attached schematic shows the existing wiring, how do I determine which wires I need to change to get 230 in and 460 out? It looks like there are 2 windings on the primary and its just a matter of series vs. parallel but I'm not sure how to go about determining which ones to connect.
    Thanks for any help
    Matt
  1. Needing Rewiring
    By universalfab in forum Employment Opportunity
    Last Post: 04-18-2010, 05:34 AM
  2. I need 3Phase 230V off 1Phase 110V, can I get help?
    By idtkid in forum CNC Machine Related Electronics
    Last Post: 07-14-2009, 02:56 PM
  3. Rewiring a 115 V router for 230 volts?
    By johnmac in forum CNC Machine Related Electronics
    Last Post: 04-03-2009, 03:21 AM
  4. Need help wiring 230V AC spindle motor
    By Heavy D in forum Knee Vertical Mills
    Last Post: 05-07-2006, 05:24 AM
  5. Howto find input amps, from output amps on transformer?
    By sendkeys in forum CNC Machine Related Electronics
    Last Post: 07-15-2004, 01:13 AM
