587,568 active members*
3,399 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Cleaning Linear rails and bearing blocks
Results 1 to 6 of 6
Threaded View
    May 2009
    264
    Hellow again folks....I have another question.
    I just received my first set of linear rails and bearing blocks. It's a Rexroth Linear Motion system (eBay find). They were removed from a working system and were only wiped clean. There is a lot of great and gunk all around the blocks.
    Can I removed the blocks from the rails without letting the bearings loose?
    Should I use a solvent to clean them or something line WD40?
    If I can remove the blocks should I soak them in cleaner and then what do I grease them with?
    I've tried to "Google" this but I am obviously looking up incorrect terms or something....
  1. THK SNS 25 Linear Rails and Bearing Blocks 53' long
    By clembrant in forum For Sale Only
    Last Post: 06-19-2014, 08:18 PM
  2. review of chinese rails and bearing blocks from Econvience
    By ajwaverider in forum Linear and Rotary Motion
    Last Post: 03-31-2013, 03:14 AM
  3. Supported Rails + bearing blocks from Ebay
    By kiwichris in forum DIY CNC Router Table Machines
    Last Post: 06-26-2011, 02:48 PM
  4. Where to get Linear rails and blocks?
    By gunlocators in forum DIY CNC Router Table Machines
    Last Post: 08-09-2008, 02:55 PM
