587,149 active members*
5,406 visitors online*
Results 1 to 5 of 5
Threaded View
    Mar 2008
    454
    Machining outside stock perimiter
    Hello,
    I am trying to machine an object with raised cylinders. The clearance between the outside edge of the cylinder and the edge of the stock is less than the width of my endmill bit. So it will not mill that area and leaves me with something not a cylinder.
    How can I fix this?
    I am trying to mill it using a pocket operation, also tried setting contour technology data to 'start from: outside' but I get the same results.
    Here is a screenshot of the simulated cutting paths.
    I appreciate any help
  1. Which way to turn stock for 2-sided machining
    By wizzardworks in forum Uncategorised CAM Discussion
    Last Post: 04-29-2011, 05:03 AM
  2. Best way to cut bar stock AL into slugs for machining?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 09-25-2008, 07:21 PM
  3. Where can i get metal stock for machining????
    By randyrw in forum MetalWork Discussion
    Last Post: 09-02-2008, 04:35 AM
  4. Replies: 0
    Last Post: 11-20-2007, 06:52 PM
  5. Stock setup and machining
    By tt_raptor_90 in forum Mastercam
    Last Post: 12-27-2005, 02:22 AM
