A little help here hoping for a simple fix..."aren't we all". The tool release piston seemed to be malfunctioning the other day when loading tools, it didn't seem to want to let go of the tool when i pushed the tool release button to pull out the tool. after a couple more tool changes it stopped working altogether. After pulling out the last tool. didn't make any wierd noises. just stopped being effective. FYI.. Umbrella typ tool changer.
after taking off the sheet metal. I watched to see that the plunger comes down on top of the drawbar. it hits the draw bar and stops like the drawbar is locked up. the spring plunger on top of the tool release piston moves down from the upper limit switch half way down until it hits the top of the drawbar then stops.
I pulled the exaust muffler from the air input line. it looks like the rubber gasket is tore up in pieces, and appears to be used as a flow control device as well as an air muffler. where to get one of these?..
I'm not sure if this is a tool release piston issue or a drawbar issue...
Thanks.
