587,983 active members*
4,460 visitors online*
Results 1 to 3 of 3
    Jun 2005
    142
    MAPPS IV, 3D INTERFERENCE CHECK
    I'm trying to set up my tool models for the interference checking, and have a problem when I set the tool# to the model (Offset>Manage>Model Info>Cutter1 Ofs. No).
    After reloading the User Model, X axis looks ok, but Z axis has wandered off about 300mm. So while the Holder (eg. straight er32 collet) stays put on the turret, the endmill is in space, almost at Spindle 2.
    Our Mori rep is on holidays and I've been told there are no other machines in Aus that have the 3D Check option!
    Thanks.
    Aug 2011
    2517
    The 3D check is on MAPPS III as well. We have several NT's with it (MSX-720/MSX-730).
    But we never use it, we just get on with machining parts
    Jun 2005
    142
    thanks for the constructive tip, so glad yours wasn't another useless response.
    I prefer to use the expensive options my employer paid for, rather than have anyone using the machine make a silly mistake which could cause big buck damage. We're all fallible.
  1. FIND MAPPS PARAMETERS
    By bobe in forum Mori Seiki Mills
    Last Post: 06-07-2011, 05:20 PM
  2. fanuc 18i msg 501 mori mapps
    Last Post: 05-26-2011, 01:49 AM
  3. MAPPS
    By littlerob in forum Mori Seiki lathes
    Last Post: 09-30-2009, 02:52 AM
  4. MAPPS CNC
    By sjh in forum Controller & Computer Solutions
    Last Post: 04-20-2009, 11:44 AM
  5. MAPPS question
    By RobinHood in forum Uncategorised MetalWorking Machines
    Last Post: 06-08-2007, 06:04 AM
