603,365 active members*
4,073 visitors online*
Thread: E/G CNC Mill
Page 2 of 4 1234
Results 21 to 40 of 70
  1. #21
    Dec 2006
    839
    Quote Originally Posted by thewho View Post
    I will mill some aluminum with small carbide cutters (<10mm) And I don´t want to be at the spindles max speed all day long. But maybe there is some margin to the 5100rpm
    There is some. But the truth is if you want higher rpm you will need to add bearings that are able. The IH spindle would be a good way to go, plus afforable. See if they will sale it wihtout the bearings so you could buy better ones. Getting a spindle to run high RPM is not the easest thing to do, good bearings a must, then the right install, plus break in.
    The guys that sale the IH clone would sale you a spindle without the bearings I believe, if IH want. The Tormach you would have to post in the Tormach section to find what the guys are getting for top RPM with the factory bearings. I know some are getting higher, but I am not sure how much.
    Jess
    GOD Bless, and prayers for all.
  2. #22
    Jul 2005
    163
    Since the Tormach PC770 will do 10K rpm, see if you can get one of those spindles, or the cartridge spindle and the upgraded bearings for the 770 spindle. Are you going to make an ATC for this mill?
  3. #23
    Mar 2008
    43
    I would like to have a atc, but for now I will use the mt2 spindle shaft I have already.
    Todays update (really yesterdays update)
    I started making a new spindle housing to make room for two ac bearings at the bottom.
    Pics are crystal clear as always with a mobile camera :tired: sorry for that.
    I'm really happy with the insert holder from ctc tools btw :banana:
  4. #24
    Mar 2008
    43
    Last nights progress:
    Drilling holes for the mounting screws
    Done:
    As always I bored the upper bearing seat a hair to much.. (chair)
    Maybe It will work with some locktite?
  5. #25
    Dec 2007
    118
    I hate when that happens maybe you could drill through the sides in 3 or 4 points and tap for some set screws to tighten against the bearing so the bearing is held tight just a suggestion.
    Mike
  6. #26
    Jul 2010
    Bore it further out and make a ring to fit the bearings.
    PS: very nice project.
    greetings & good luck
  7. #27
    there is loctite especially for this purpose.
  8. #28
    Dec 2006
    839
    Quote Originally Posted by T.W.O. View Post
    Yes, this plus the Loctite meantioned will take care of this. You need to sleeve/ring it or you will not hold the bearing right, so no set screws. BTW this would b exactly how someone would repair a part like this that had the bearing spin and eat the housing out.
    Jess
  9. #29
    Dec 2007
    118
    Quote Originally Posted by LUCKY13 View Post
    Jess
    Maybe I am the only one who actually looked at the pictures does it look like there is enough material to bore this without the threads breaking through? A sleeve is the obvious way to fix an oversize bore if you have the wall thickness to make the bore bigger.
    Mike
  10. #30
    Dec 2006
    839
    You have a point there, doesnt seem to be enough room. IDK about counting on locktite along to hold the bearing right. I wander if the bearings can be ordered a few thou oversize?
    Jess
  11. #31
    Mar 2008
    43
    To clear things up, its the upper end bearing seat that is to big. Not the "business" end
  12. #32
    Mar 2008
    43
    Small update. I've started with the electric cabinet (?)
    These are the transformers I'm using
  13. #33
    Mar 2008
    43
    It has been a while since the last update but the machine has now moved for the first time. (video in the end)
    Done some tapping (chair)
    Some electrics
    Machined some of the parts
    Seems to fit
    Bought a cheap face mill 55eur with 10 inserts
    Paint
    Finished the spindle. It's just a mt2 for now
    Starting final assembly
    Tried out the new mill, works great
    The 1.5 kW motor
    And the video :banana:
    [ame=http://www.youtube.com/watch?v=4coobzRqONg]3 Axis test.mp4 - YouTube[/ame]
  14. #34
    Feb 2010
    331
    looks pretty darn good. how did you get the shiny surface on the e/g?
  15. #35
    Dec 2004
    1865
    Looking good,
    Can't wait to see it do some machining.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  16. #36
    Mar 2008
    43
    Shiny surface?
  17. #37
    Feb 2010
    331
    like in this pic
  18. #38
    Jul 2008
    199
    Quote Originally Posted by Zygoat View Post
    like in this pic
    He already wrote that he got a huge piece of granite for the base. It is granite not the e/g.
    (check his initial posts)
    It is better to die for something than to live for nothing.
  19. #39
    Mar 2008
    43
    Heres a late update for you.
    [ame=http://www.youtube.com/watch?v=kunIWL1Hqj0]Way covers - YouTube[/ame]
    Milled the table flat (not with the mill in the spindle)
    First real project with the mill. New pulleys for a HTD 8m belt.
    I broke my last 4mm mill when milling the second pulley and now I have to wait for new to arrive..
    Did another project while waiting
    Had some problems hehe..
    Didn't get a awesome surface finish..
    [ame=http://www.youtube.com/watch?v=8EG2zOxmVeM]Cutting test 50mm face mill - YouTube[/ame]
    If you want the latest info you can run this page trough google translate
    Svenska ElektronikForumet • Visa tråd - Daniels stora fräs //It's alive! Nu med film
  20. #40
    Mar 2004
    1306
    Cool Build Thewho. Great to see someome doing something in Mineral epoxy rather than just theorising over it.
    In Post #7 it looks like you used a pneumatic vibrator attached to the mould http://i1186.photobucket.com/albums/...926_215812.jpg
    Is this the design with the bearing ball providnig vibration? How did it work out for you?
    What were your thought about putting the unfinished side of the EG saddle uppermost? I would have thought that the unfinished part of a mould would be better hidden below.
    What was the mould material? What mould release agents did you use, did they work well?
    Regards,
    Mark
Page 2 of 4 1234
  1. How to drill and face mill using table type horizontal boring mill
    By SatishNaik in forum News Announcements
    Last Post: 10-09-2013, 01:10 PM
  2. Replies: 0
    Last Post: 07-29-2013, 01:15 PM
  3. Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head
    By fignoggle in forum Benchtop Machines
    Last Post: 05-12-2009, 05:11 AM
