That's the one.
Al.
That's the one.
Al.
Albert E.
finally got around to this.
I'm getting 25ohms on all three possible termination combos...
I expected the common like you said to show the same but the other terminations (where the cap would go) I expected double the resistance.
What aren't I understanding ?
?? The same resistance between any pair would indicate a 3ph motor?
Al.
Albert E.
I agree...
But there doesn't seem anything that special (1ph to 3ph) in the burned out control box - unless it can be done in some inefficient relatively partless manner ?
I'll investigate more...
Damn, I was hoping this was easy !
I do have a Seimens VFD here - (micromaster 420 at 3kw)
hmmmm
As you got it used, is it possible the motor had a controller on it at some time?
I assume it would be a 220vac motor, seeing where your located?
Might be worth a shot trying the VFD?
Al.
Albert E.
well, yeh
I mean, what could go wrong ?
I've already started one fire on this machine -
so... just wire it up UVW ...
I've barely used it so I'm a bit green on VFD specifics
Set the current trip limits low ?
What to watch out for ?
Even if I didn't change a thing in the drive worst case it should protect itself huh ?
The majority of VFD's have quite a bit of protection built in.
Often the default parameters are enough to do a primary test.
If it power up OK, use the manual keypad to run at a low freq/rpm at first.
When you come to enter the parameters it would be nice if the motor details were known, if runs, operate at a set frequency and measure the rpm if possible, this will at least tell you if it is a 2 pole or 4 pole motor.
Al.
Albert E.
Nick - I just found this thread and am very interested in how it turned out as I too have a V10P that I am rewiring. I'm changing the lathe motor to 3-phase with VFD, but would rather leave the mill head as is. It was unconnected when I got the machine, so I'd like to know:
1) Is the mill head supposed to be reversable?
2) Can the cap-run mill motor actually be run with with a VFD?
So Nick, how'd your machine turn out?
Albert E.
