587,547 active members*
3,369 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > 3D engraving and contouring
    Aug 2008
    36
    Ive been on FC for 4 years now, and I still revert back to Mastercam for one simple thing. a 3D contour. ( Its very simple in MC ) I needed to engrave a logo on a 3d surface and I had to write it in mastercam and cut/paste the code into the rest of my FC program.
    Recently at a 2012 update, the instructor showed us very briefly' how its done, and i cant seem to figure it out. I want to create a curve at the base of a radius along a 3d surface and mill along it without using a surface mill feature. I think he used a surfmil along a curve with boundry. But i cant close a single line boundry.
    Any suggestions??? thanks
    Kris
    Jun 2005
    69
    create your engraving at or above z 0, selct the surface you want to engrave on and create a 2D spiral tool path with a wall pass check box. that should get you going- let me know.
    Jun 2005
    69
    i forgot- use your text as the boundry!!
    Jun 2005
    69
    Create your text as you want it to appear on the surface. It doesn’t matter where in Z – the letters get projected onto the surface. Because of this, the letters are a little distorted if you look at them from the side.
    Once you have the text, create a surface mill feature from the surfaces you want to engrave. Use a 2D spiral-finish strategy. When you get to the Boundary section, select “Use curve as boundary” and then click Curve Options. Select the Wall Only choice and select your text curve with the Boundaries button. The tool should mill along the surface, following the shape of the letters. To make the tool cut into the surface, give it a negative leave allowance.
    This should be a little clearer- had some time!!
    Let me know if you have any trouble with this.
  1. 2d Contouring
    By scottsss in forum SprutCAM
    Last Post: 10-04-2011, 11:48 PM
  2. Engraving Around a Cylinder Using 2D Contouring
    By dkaustin in forum SprutCAM
    Last Post: 06-04-2011, 07:39 PM
  3. Help Need Help With 3d Contouring
    By D5PENNIES in forum Hobby Discussion
    Last Post: 04-03-2007, 02:24 AM
  4. 3D Contouring????????
    By cut2spec in forum Benchtop Machines
    Last Post: 03-18-2007, 07:08 PM
  5. contouring help
    By rbest27 in forum Surfcam
    Last Post: 02-02-2007, 04:14 PM
