587,682 active members*
3,480 visitors online*
    Oct 2011
    218
    Air compressor
    Im looking for a air cooling solution for my cnc, I mostly cut acrylic onmy machine but sometimes aluminum .
    I have a standard 2.5hp compressor which I use to blow air onto tool for cooling, this works ok for me , but the compressor is louder than the cnc. Want too find a quite compressor with high airflow, or some other type of quite air pump.
    Any ideas would be great, I'm in Australia
    Cheers.
    Ps. Thought about mist but not sure if it will work with kress router, & don't you have too keep buying coolant.
    Mar 2006
    2712
    A screw type compressor is quieter than a piston type, but they are kinda noisy as well. You may have to install an enclosure around the compressor.
    One of my earlier employers had to build an addition to the shop and moved the compressor into the new room which was built for sound reduction.
    Dick Z
    DZASTR
    Feb 2007
    664
    we just bought a qgs-7.5 ,7.5 hp screw compressor, nice and quiet
    the fans on the machines are louder
    quincycompressor dot com
    Oct 2011
    218
    Thankyou for all replys, so I think I need too keep an eye out for a rotary screw compressor then . Thanks all nice 1.
    Cheers
    Riche.
  1. DIY air compressor
    By joecnc2006 in forum Hobby Discussion
    Last Post: 07-05-2014, 07:11 AM
  2. compressor
    By WATERJET71 in forum Haas Mills
    Last Post: 05-31-2011, 11:17 PM
  3. compressor help
    By advt001 in forum MetalWork Discussion
    Last Post: 04-07-2010, 04:04 PM
  4. New Compressor Help
    By 1ctoolfool in forum Haas Mills
    Last Post: 02-01-2007, 12:52 AM
  5. Compressor
    By Crazycorkey in forum Hobby Discussion
    Last Post: 01-30-2007, 10:02 AM
