587,858 active members*
3,558 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 4th Axis Drive...User Install?
Results 1 to 18 of 18
    Dec 2008
    319
    Curious if it is possible to install the 4th axis drive myself?
    Seems like the HAAS add ons are a plug and play with ample directions.
    Jan 2010
    18
    I was told it was a pretty simple install. I'm going to do it on my new Mini Mill. The local Haas service center has always helped me with repair issues over the phone and said they would help with the 4th axis drive if need be. Probably will not do it for a few more months since my other two machines already have 4th axis. Besides, I'm sure there is plenty of help here on the board is case you get in a jam.
    Jul 2005
    12177
    Based on my experience, yes and no. Although it is not really my experience, it is looking over the shoulder of the tech doing the install. One machine on which I had the 4th axis installed after purchase was real pain and needed a complete software reload. Another was a case of plug, plug, key press, key press and everything worked fine.
    But are you going to save much? I thought the price for all the bits and pieces included installation; I know it did in my cases.
    Dec 2008
    319
    Quote Originally Posted by Geof View Post
    I don't know yet. I'm going to have them quote both ways.
    Tim
    Dec 2006
    75
    My HFO told me about 6 months ago that install was not included in the price of the parts. At that time they wanted an extra $800 for the install.
    Hercules
    2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
    Feb 2010
    1184
    How old is your machine? Are you looking at brush or brushless rotary?
    Either way it should be pretty straight forward.
    Dec 2008
    319
    Our machine is a 2008, just picked up a brushless HRT210 for it.
    Tim
    Feb 2010
    1184
    If you are comfortable working on your machine then you should be able to handle the install without any problem.
    You are probably looking at installing a cable connector from the side of the cabinet and plugging that into a pcb.
    Install the servo amp with a cable from the amp to the mocon pcb and wires to connect into the DC Buss
    Plug in your rotary
    Turn machine on and activate 4th Axis parameter if not already turned on (you will need a code)
    Select rotary from the list in settings.
    Start machining
    I may have forgotten a thing or two but take your time and you should be good. Let me, or your HFO, know if you have questions or issues.
    Good luck.
    Dec 2008
    319
    Thanks!
    My dad is an EE so I'm not worried about the install. I will post here with pictures as I go.
    Tim
    Dec 2006
    75
    Hey behindpropeller, I know this is a bit of an old thread but I wanted to ask if you ever did the 4th axis wiring install. I was finally ready to purchase the wiring and an HRT 160 last week but when talking with my HFO to arrange the order they are now telling me that the install for just the wiring kit will be $1200. Then mabe another hour or two service charge to set up the rotary. Obviously I'd like to do it myself if I can and save that cash. My mill is only a few years old and the install would be for a brushless unit so it would be similar to yours if you ever did it.
    Hercules
    Feb 2009
    6028
    I just did one last week on our TM2. Easy as can be. Came with instructions as well.
    Dec 2008
    319
    I never pulled the trigger on the kit.
    The part I had lined up to do it on is currently on hold.
    Under the tire..... What is the current cost of the wiring/boards?
    Tim
    Feb 2009
    6028
    Honestly don't know. We ordered it with the machine, however Haas sent it in a box...?
    Aug 2010
    579
    Quote Originally Posted by underthetire View Post
    What was sent in a box? The 4th axis drive card and wiring that goes inside the control cabinet? Or, the rotary that just plugs into the side of the control cabinet?
    Thanks,
    Ken Foulks
    Feb 2009
    6028
    The drive and cables. Thought it odd, since the additional Mcodes were installed.
    Dec 2006
    75
    Quote Originally Posted by behindpropeller View Post
    Tim
    $2395 is what shows on the web site (+ install cost according to my HFO)
    Hercules
    Aug 2010
    579
    Hercules,
    We do ship the 4th axis drive out as a service kit with instructions. Having your HFO install the drive has the added benefit of a warranty.
    Thanks,
    Ken Foulks
    Dec 2006
    75
    Thanks for that info, no one at my HFO mentioned the warranty difference.
    Hercules
  1. Panasonic drive user manual
    By mizaro in forum Servo Motors / Drives
    Last Post: 01-09-2011, 07:59 PM
  2. USB drive field install
    By btomlinson in forum Haas Mills
    Last Post: 09-04-2008, 06:02 AM
  3. belt drive install problem
    By goofin in forum Benchtop Machines
    Last Post: 06-06-2008, 12:41 AM
  4. GD Servo Drive user experiences
    By Xerxes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-03-2008, 12:01 PM
  5. How to install 4th axis in SX3?
    By Involute in forum Syil Products
    Last Post: 08-13-2007, 05:39 AM
