588,228 active members*
4,523 visitors online*
Thread: Skip Signal
Results 1 to 11 of 11
    Dec 2003
    24220
    The skip input cannot be made conditional so it does not show up in the ladder AFAIK.
    When writing G31 routines or macro's it is customary to have a protected positioning move, this is a routine that would typically be used to move the probe to initial position in say rapid, IOW, any move of the probe should include a G31.
    The standard G31 input is sent from PLC to CNC via the BMI, an optional High speed skip input is available through an add on board and option parameter that directs the high speed G31 skip input directly to the CNC side.
    Al.
    Albert E.
    Aug 2007
    58
    Hi Al,
    I've been thumbing through the manual -
    It says that the input interface signals 1 to 32 can be read by variables #1000 to #1031.
    I'm hoping that the skip x4.7 is connected to one of these i/ps
    I haven't got the electrical drawings with me, so I'll have to check when I get to work tomorrow.
    I just want to check the probe closes on the back off move...just a bit of error checking realy, or that the tool hasn't mashed the tool setter ;-)
    I wasn't sure if i could use a G31 with a G0 - I'll give that a try too.
    ATB
    Sep 2010
    1230
    Quote Originally Posted by derekBPcnc View Post
    Hi Al,
    ATB
    No you can't. G31 is a one shot command that is terminated by the slide reaching the end point or by the change of state of the switch, and functions similarly to G1. Accordingly, if you want rapid movement in the G31 block, include a fast feed rate.
    You have the logic correctly planned. The switch should be made when the tool/probe is in fresh air. A broken wire etc in the system will therefore fail safe.
    Regards,
    Bill
  1. New skip in the house
    By latheboy in forum Community Club House
    Last Post: 08-20-2011, 05:30 AM
  2. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  3. Fanuc 15M skip signal
    By 67highboy in forum Fanuc
    Last Post: 09-11-2008, 04:13 PM
  4. Block skip function
    By Vern Smith in forum Haas Mills
    Last Post: 07-31-2007, 01:50 PM
  5. Removing the block skip /
    By Shizzlemah in forum Fadal
    Last Post: 02-17-2006, 05:01 PM
