I just started using a tree mill with a dynapath delta 20 control.
The only problem I have ran into with the machine function is the screen will run occasionally like an old tv set.
Is there an adjustment on it to correct this?
Common problem. Most people just smack the left side of the control pretty hard. They have been doing that to the one here for 14 years!
Todd
There are also the typical Horz Vert Contrast control pots inside the cabinet if the above method does not work.
Agreed, trying to fix the problem is what I would try to do, the service tech said smacking the control works for him. Mine hasn't done that yet so I've not been able to try the adjustment method yet.
Todd
