588,423 active members*
6,333 visitors online*
Page 5 of 5 345
Results 81 to 99 of 99
  1. #81
    Aug 2008
    303
    Very nice !!:cheers:
    I noticed you water is about 1/2 -3/4 below the work surface. Are you getting much dust in the air ? What about dross ?
    I started building my table this week, but made the water tray somewhat adjustable. Some say to have the water just below the work ( like yours ), others are saying to have the water 4-5 inches lower.
    I'll start my build thread here once I have more pictures.
    Good job,
    Dan
    Welcome to www.dantechfabricating.com
  2. #82
    Jul 2011
    86
    Quote Originally Posted by Danno View Post
    Good job,
    Dan
    Dross on the aluminum I don't need to clean, it is almost non existent. On 3/16 steel plate it takes a quick scrape around the edges to remove but no grinding is required for my needs.
    The water catches 95% of the airborne dust, only a little on the machine rails after a month of use.
    The bottom of the tank has a ton of material and will need to be cleaned again soon, so it is catching most of the material.
    I have thought about putting a vent on the side and running it to the roof of the house as I have a space 8" flue to the roof from the garage. This would allow me to cut with the roll up closed.
  3. #83
    Aug 2008
    303
    Quote Originally Posted by DirtBound View Post
    Funny you mention that !! That's what I did to my table. It's vented on the side rails in hopes that it will catch anything that the water missed.
    I will try and post my build pics tonight.
    Dan
    The one that dies with the most tools, WINS !!
  4. #84
    Jul 2011
    86
    Finally cut some 1/2" steel with it and WOW! I followed JimColts instructions found online and it did a great job.
    14IPM for the hole, 1" round with .040 bevel
    The outside is 20IPM and about 1-2 degree bevel.
    The edge was not ground at all exempt the very tip where it was pierced.
  5. #85
    Jul 2011
    86
    Looks like I may have burnt my x axis out... Last night we had a few errors in mach3 "driver watchdog" and today I upgraded Mach 3 to the latest version and it works on all axises but x, x moves like it is missing parts to it and not moving smoothly.
    I found the fan on the TB6560 not working so possibly the chip overheated?
    I am going to trouble shoot tonight and tomorrow but I may be installing a G540 monday or tuesday...
  6. #86
    Apr 2011
    33
    Yep, that sucks.
    That's how mine went out.
    Unfortunately, I broke my new G540. But you know what? Gecko support is fixing it for free. Can't beat that with a stick. The performance of the G540 for just the few minutes I got to play with it was amazingly noticeable.
    Thanks for the pics of the settings I asked for.
  7. #87
    Jul 2011
    86
    Quote Originally Posted by rodder View Post
    Yep, that sucks.
    How did you fry the G540? They are local to me so I am going to see if they will let me drive over and pick one up monday, I was going to work on a bunch of prototypes this weekend so this was horrible timing for it to fail.
    Sorry about the screen shots, i got way busy and just looked. sure enough a unread PM from you a month ago... (chair)
  8. #88
    Jul 2011
    86
    I got the G540, good thing GeckoDrive is local to me so I took a drive and picked it up in person. They are great people.
    Hooked it up and it is super smooth, the steppers are near silent and the cutting is amazing, before on certain radiuses it would look all jagged, but not anymore.
    Here is a rear bumper I am working on, Cut on the CNC and then bent on my custom press brake.
  9. #89
    Oct 2008
    95
    NIce work. How about a picture of your brake?............jb
  10. #90
    Jul 2011
    86
    The press, it is massive. 55" wide mouth, with a 37.5" wide die. I am adding some bracing to the frame this week.
    And the finished bumper
  11. #91
    Feb 2010
    3447
    Cut delay fixed - YouTube
    Much better without that delay!!!
    AMAZING!! Do you do any small side jobs? May have to send you a couple test files i wanted cut out of sheet aluminum to see the cut quality before i dive in.
  12. #92
    Jul 2011
    86
    Quote Originally Posted by diyengineer View Post
    Yea I could do that, you should see how smooth the machine runs with the Gecko G540. I thought it was the machine that caused the wobble, but I was wrong it was the TB6560.
  13. #93
    Oct 2008
    95
    Thanks for the look at your brake. I need to find a deal on one..........jb
  14. #94
    Jul 2011
    86
    I built the press for about $450 including the brake die.
  15. #95
    Dec 2005
    173
    Nice job on the bumper! Thanks for showing your brake design.
    Brad
  16. #96
    Feb 2010
    3447
    Shoot me your email address in a message!
  17. #97
    Sep 2011
    54
    split collar
    Dirtbound, nice job on the build. I am working on one now. Can you tell me where you bought your split collar to hold your torch?
  18. #98
    Jul 2011
    86
    Quote Originally Posted by lik2waterski View Post
    It is just a shaft collar from the hardware store, I want to replace it with this one from mcmaster as it requires no tools to open.
    McMaster-Carr
  19. #99
    Sep 2011
    54
    Thanks for the link. I appreciate it!
    Travis
Page 5 of 5 345
  1. Starting my "PlasmaBot" 4x4' table build!!!
    By winegar in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 01-28-2013, 10:53 PM
  2. Yet another "PlasmaBot" build :D
    By cobretti in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-11-2011, 01:19 PM
  3. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
