587,263 active members*
3,355 visitors online*
Results 1 to 10 of 10
    Nov 2011
    Exclamation problem with the system FANUC M6
    I have a problem with the system FANUC M6 after attached powering on the monitor a message displays - FIFO NOT READY. Error code does not appear, etc. I measured all the voltages on the motherboard and expansion cards – they are OKThe machine documentation does not contain any information about this problem and that message. Now, I have a question and I must ask for help. How can I diagnose this fault and where I need to look for it?
    In the picture you see a message from the screen.
    I add the numbers on the system motherboard: AI6B-1000-0030/06C
    Aug 2011
    2517
    looks like a motherboard fault. specifically the fifo chips are not working
    Nov 2011
    If this is a problem how to solve it?
    Aug 2011
    2517
    repair motherboard or replace it with new/refurbished motherboard
    Nov 2011
    another solution to this problem is not there?
    Aug 2011
    2517
    sure. send me the air fare and I'll fly out tomorrow and repair it for you
    seriously though, you have an electronics fault. it requires someone who has knowledge in repairing CNC-specific electronics. Only other way for non-tech person to fix it is to replace the entire faulty unit.
    Nov 2011
    Ok Thx
    So, Do you ever met with this problem?
    Aug 2011
    2517
    yes, once, but it was not the same system as yours. I replaced the surface mounted FIFO IC's
    Nov 2011
    Helped?
    Aug 2011
    2517
    Helped? huh?
  1. FANUC SYSTEM 10TE-F SERVO PROBLEM
    By tano in forum Fanuc
    Last Post: 07-07-2010, 11:59 PM
  2. data downloading pc to cnc problem in 0MC/0MD fanuc system
    By vk_rathi in forum MetalWork Discussion
    Last Post: 04-07-2009, 12:40 PM
  3. Chiller system problem
    By fadalman in forum Fadal
    Last Post: 07-15-2008, 04:07 PM
  4. new system, new problem
    By draughted in forum Mach Software (ArtSoft software)
    Last Post: 04-21-2008, 03:41 AM
  5. Replies: 1
    Last Post: 11-22-2007, 02:55 PM
