588,548 active members*
5,700 visitors online*
Results 1 to 16 of 16
    May 2007
    86
    Leadscrew lubrication/lube
    I know I have read some recommendations here before, but I have been searching for an hour now and can't seem to find them. What do you use to lubricate your leadscrew? I have 2 start Acme lead screws with dumpster anti-backlash nuts. They are rather stiff and when I run my machine, I get some vibration.
    I'm going to double check alignment, etc, but in the meantime, I'm looking for a recommendation on a lube to use. I prefer something dry so that I don't get sawdust, etc sticking to the screw and causing more friction.
    Thoughts?
    Apr 2007
    8082
    Dupont Teflon Multi-Use Dry, Wax Lubricant spray. It's sold by automotive stores and Lowe's. It evaporates and leaves no appearance of anything like grease on it. Works pretty good for me. Garage door spray lube is similar and works well also.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2010
    363
    I use a silicon based "Dry lube". I think its made by CRC. It behaves very close to what CarveOne is describing.
    Apr 2007
    8082
    After a few re-coats of the Dupont stuff you will see little curls of a light tan substance coming out of the "fingers" of the DumpsterCNC nut, This is the normal wax buildup oozing out. If it is black Delrin plastic coming out you have a really cheap, rough lead screw with wire edges on the threads. Been there, done that. It can be repaired with hand polishing the tops of the threads, though you may already need new ABNs.
    CarveOne
    CarveOne
    May 2007
    86
    Awesome, I'll head out to lowes or autozone today and try to find some.
    Apr 2007
    8082
    If your local Lowe's is laid out like mine, look in the tool center area along the main aisle on the shelves where the grease and lubricants are located. There are also some CRC products there I think.
    CarveOne
    CarveOne
    May 2012
    124
    I know this thread is old but...any reason we cant use PAM? ie the cooking pan stuff? i use it to keep the chute on my snowblower clear.
    35538
    I don't think PAM is slippery enough. I use pneumatic tool oil. It's very thin, and works great. Just put a few drops on the screw, run the machine back and forth a few times, and wipe off any excess with a rag.
    Feb 2009
    6028
    Bike chain lube is also good for this, white lightning I think is the brand sold at most Walmarts, stuff really works quite well.
    Dec 2003
    24221
    On a mill or a lathe, the lube system for the B.S. is the same source as for the ways, and is usually Vactra2 way oil, it is rather tacky to the touch and attracts dust, but I would think a B.S. on in a router environment you would need a collapsing cover of some sort due to the dust problem?
    Al.
    Albert E.
    Nov 2006
    1036
    +1 on pneumatic tool oil
    I've been using this for more than a year per Gerry's recommendation. Works great! Dust accumulation has not been a problem.
    Haven't seen your posts for a while. How is your machine working?
    Aug 2005
    437
    I use wax, I take my wife’s old burnt down candles and melt them down is an old double boiler, then poor the wax in an old muffin tin. I save the little cakes to rub on the lead screw. It’s worked for me and being dry it doesn’t hold the dust. I am running all-thread rod and homemade Teflon nuts.
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
    Sep 2012
    1543
    I use Royal Purple Max Film and once and awhile Schaeffer Moly EP, it lasts "forever"
    Jun 2012
    817
    I use CRC 336 with good results.
    Apr 2009
    5516
    Quote Originally Posted by Devastator View Post
    I have started using CRC 2-26 and it works great! Also is safe for all plastics...
    Dec 2007
    2134
    The one I mainly use for almost everything is "fluid film". It sprays on, and being a natural lanolin based lubricant makes the shop smell nice when machining. It sort of develops a film that isn't tacky or resistive like grease or thicker oils go. It's the best general purpose lube and rust preventative i've found.
    cheers,
    Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  1. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  2. Slide and Leadscrew Lubrication?
    By forrestc in forum DIY CNC Router Table Machines
    Last Post: 07-10-2007, 05:31 PM
  3. Lubrication
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 04-29-2007, 07:13 AM
  4. Acme leadscrew or Trapezoid leadscrew is better?
    By minicnc in forum DIY CNC Router Table Machines
    Last Post: 03-07-2005, 06:57 PM
