588,211 active members*
4,252 visitors online*
Results 1 to 5 of 5
    Dec 2011
    Random g540 Faults
    Is there any way to get more information about why the Gecko g540 is going into fault? This recently started happening after a few months of use. I am using EMC2 Linux CNC software. The program will be running along fine and then all of a sudden the g540 goes into fault, random times, no apparent reason. The EMC2 software appears to keep going along as if nothing has happened. Any EMC2 users out there? Does EMC2 do an logging at all? I haven't been able to find any.
    35538
    DO you have a heatsink or fan on the G540? Is it getting hot?
    Dec 2011
    No heatsink but my work space is only 55 maybe 60 degrees F. The g540 feels only warm to the touch. I can hold my hand on it. One thing I have recently done is added a wifi card to the computer. I am going to disable it and see if the problem persists. I don't know why that would impact the system like this but it is worth a shot.
    Mar 2005
    335
    did that work?
    if you move the parallel cable does that cause it to error?
    Dec 2011
    No, it didn't. I ended up replacing the computer and got mach3 instead. It has been fine since. Thanks for the help tho!
  1. HELP, mach throws up random ESTOP mid program. Gecko G540
    By dougie329 in forum Mach Software (ArtSoft software)
    Last Post: 12-04-2011, 07:35 PM
  2. g540 Faults with more than 2 motors hooked up?
    By R08ert209cali in forum Gecko Drives
    Last Post: 11-28-2011, 08:26 PM
  3. G540 Random fault light on power up
    By mchm66 in forum Gecko Drives
    Last Post: 09-05-2011, 09:51 AM
  4. random stalling g540
    By ihavenofish in forum Gecko Drives
    Last Post: 05-04-2009, 06:49 PM
  5. TM1 faults
    By f1jdm in forum Haas Mills
    Last Post: 01-11-2008, 12:22 AM
