587,267 active members*
3,966 visitors online*
Results 1 to 6 of 6
    Dec 2011
    Best machine to cut marzipan or icing sheets?
    Hi guys, I have absolutely no experience with CNC machines but am on the hunt for the best way to cut small shapes out of marzipan or icing sheets to be used in cake decoration...
    Any advice would be greatly appreciated....
    I'm wondering if the best plan of attack would be to freeze the sheets to make them stiff and then use some type of router type spinning drill bit to cut out the shapes?
    But I'm hoping someone with more experience might be able to give me some good advice....
    Laser, blade, spinning bit etc????
    Feb 2009
    2143
    No idea of your budget but water jet cutting is a great method for cutting foods....
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Dec 2011
    Quote Originally Posted by mcphill View Post
    Thanks for that info.... Will look into that too.... Home craft sort of budget so less than $1000 hopefully for a suitable method...
    Apr 2008
    204
    I would attack it from another direction. Make molds or cutters with a cnc to cut or form the icings. I would hate to be the one cleaning the rails of icing and marzipan at the end of each day and having to re-lube everything.
    35538
    These machine use knives to cut the material.
    Cricut Cake
    I'd guess that the blade approach would be best.
    Dec 2011
    Cricut Cake
    Yeah after a bit of web surfing I did stumble upon the Cricut Cake device which is a small blade based system. Just need to work out if I can load my own designs, doesn't look like it can be connected to a pc as all the "smarts" is in the device and the little cartridges of designs.
    I'm beginning to think a blade based system for the larger stuff and then some sort of ink jet printer type device for the smaller more intricate text and design touches...
  1. I need to buy a small laser cutting machine for pc sheets
    By memerik in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2011, 02:47 AM
  2. X3 SET UP SHEETS
    By CNC_BOB in forum Mastercam
    Last Post: 03-17-2010, 03:10 AM
  3. What CNC machine do I need for Aluminum sheets up to 0.09"??
    By jascamera in forum DIY CNC Router Table Machines
    Last Post: 12-25-2009, 06:05 AM
  4. set up sheets
    By 1234567 in forum BobCad-Cam
    Last Post: 10-27-2009, 07:38 PM
  5. Need CNC machine to cut .01" 302 full hard SS sheets (6" x 20")
    By Lowe in forum Want To Buy...Need help!
    Last Post: 03-23-2009, 06:58 PM
