588,490 active members*
4,272 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Need Help - Final steps before movement
Results 1 to 20 of 20
    Jul 2011
    I am currently in the process of building a FLA 300. The machine is fully built with the exception of finishing the cutting surface. The issue that I am having is with the g540. I have followed the tutorial on the gecko website but still arrive at the same problem of mach3 not recognizing that the e-stop is connected and not allowing the g540 to come out of fault mode.
    Here is what I have done.
    Wiring to power supply
    Wiring from g540
    E-stop wiring
    Parallel port setup on computer
    Charge pump setup in Mach3
    Error
    I'm probably missing something very simple but I have been unable to figure out what it is. Any help would be appreciated.
    Thanks, Tim
    Nov 2006
    1036
    Looks to me like your e-stop is not wired correctly. You should connect your leads to the NC (normally closed) and the common contacts. You do not want to connect to the NO (normally open) contact.
    Here's a link that might help you: http://www.cnczone.com/forums/diy-cn...ecko_g540.html
    Nov 2011
    Hi Tim,
    I have a G540 as well and this is how it is set up:
    Power supply V- to E-Stop normally closed,
    E-Stop normally open to G540 pin10
    Power supply V- to G540 pin12
    Power supply V+ to G540 pin 11
    In mach for my E-stop I have, config>ports and pins>input signals, scroll down to E-Stop and tick enabled then tick 'Active Low'
    Reset mach and it should get going. I don't have my machine 100% complete yet but my electronics are working when tested.
    Hope this helps.
    Rory
    Jul 2011
    Quote Originally Posted by DonFrambach View Post
    Quote Originally Posted by rnm85 View Post
    Hi Tim,
    Hope this helps.
    Rory
    I'm pretty new at this so I just took a shot in the dark attaching the gecko to the NO contact because I couldn't find a C contact. I tested some of the suggestions in the other thread and have figured out that e-stop is the problem. Using a jumper and turning the charge pump off gives me a green light instead of with the previous config I was getting a red light.
    Roy,
    I tried your method and it helped out with getting mach to work. The only thing is that I still don't have an e-stop that works.
    I'm going to try to see if I can figure a way to get the e-stop to work, if not I'll see if I can find a new one.
    Thanks for the help. I'll let you know if I figure it out.
    Nov 2006
    1036
    Quote Originally Posted by JTMRMC14 View Post
    ...I'm going to try to see if I can figure a way to get the e-stop to work, if not I'll see if I can find a new one.
    There HAS to be another connector somewhere on the switch besides the "NC" and "NO" contacts shown in your photo.
    Jun 2010
    178
    Your switch is not wired right, should be another contact at back.
    Jul 2011
    I can't seem to find it. There are four contacts. A NC an NO on one side (pictured in first post) and the direct opposite side looks the exact same. On the other two sides there are just the screws that stop together.
    I have found a work around for right now. If I connect the gecko to a NC and the other NC to -V I can get a green led on the board. The only issue is that I have is since I have used the 'Active Low' in the configs of the e-stop in mach 3 the e-stop only stops the board and doesn't register in mach. It's ok for now but I'm still in the process of getting everything settle so I am still going to be looking for a better solution.
    tim
    Mar 2011
    584
    Check for continuity between the NC terminal and to one of the terminals on the other side of the switch, with the switch pulled out. When the switch is pushed in it should be open.
    Nov 2006
    1036
    You should check, but I'm pretty sure you want to connect to the two "NC" contacts.
    35538
    Put a meter across the two NC contacts, which should have continuity with the button "UP". If so, then those are the 2 that you use.
    Dec 2003
    24221
    Thanks, Tim
    As a few have pointed out, you have the E-stop circuit connected to two separate switch contacts, one N.O. one N.C. these are never common to each other, hence the E-stop circuit will never be closed, on the opposite side of the block to the N.C. there should be another N.C. terminal, these are the two to use.
    Al.
    Albert E.
    Jun 2010
    178
    Listen to Al, he's right.
    Also, good luck!
    Jun 2005
    176
    Here's the internals of a standard single pole, double throw microswitch. You will see that in the relaxed state, the NC connection is made to the COM connection. When the switch lever is operated, the connection to the NO contact is made. Depending on how you want the software to behave when the switch is operated will make you use a combination of either the COM and NO contacts (switch conducting when operated) or the COM and NC (switch conducting at rest) my guess is that you want the switch to work when activated so use the COM and NO terminals.
    Nov 2006
    1036
    Actually, for the G540 you want a normally closed Estop!!!!
    Jun 2010
    178
    His switch doesn't have a COM terminal, just two sets of NO and NC terminals.
    Jun 2005
    176
    So its double pole single throw, strange. Do these come as part of a kit? Seems like a very non-standard switch.
    Dec 2003
    24221
    Quote Originally Posted by Benonymous View Post
    Actually this is very standard for a push button switch, whether E_stop or normal operator P/B.'s also many of the component type such as Telemecanique, Square D etc have blocks that can be added or stacked in N.O. or N.C. configuration.
    What you are showing is the norm for limit/micro switch action types.
    Al.
    Albert E.
    Jul 2011
    Alright so I solve the issue with the e-stop. Thanks Al.
    The next step is getting the motors moving with mach. Any threads that would help a beginner get moving?
    Mar 2010
    371
    This thread has already been pointed out to you. It's probably what you are looking for
    Dec 2010
    634
    There's one last thing I needed to do to get the e-stop working correctly with my G-540.
    In the General Config page, there is a checkbox labeled "ChargePump On in E-stop" which should be checked.
    With this box checked and the e-stop enabled in the Ports and pins page, Mach 3 will recognize when you press the e-stop button.
    Without this box checked, you can't get Mach 3 out of e-stop if the e-stop function is enabled in ports and pins.
    If you disable the e-stop input (use emulated only) the e-stop will work on the G540 but, Mach 3 won't realize that an e-stop event has occurred when you hit the switch.
    At least, that's what my experience with it was.
    Seemed weird to me but it worked.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  1. Final Day - 20% OFF all Lasers!
    By Hurricane21 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-28-2011, 09:28 AM
  2. Final decision
    By JINX222 in forum Haas Mills
    Last Post: 04-23-2007, 02:24 AM
  3. Final decision
    By JINX222 in forum Fadal
    Last Post: 04-14-2007, 07:27 AM
  4. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
  5. final pipe
    By D5zUga in forum Rhino 3D
    Last Post: 10-20-2004, 10:13 PM
