588,537 active members*
4,444 visitors online*
Results 1 to 7 of 7
    Apr 2011
    13
    Fanuc 10t Alarm OT116
    The alarm is OT116 and the description of it is
    OT 116 Disconnection Pulse Coder Bad Pulse Coder. Broken Cable.
    How can you tell if it’s X or Z
    Sep 2007
    371
    This alarm is usually a broken cable, check both, z axis is most common to fail so, check first the z axis cable.
    GP.
    Apr 2011
    13
    We do a lot of broaching on this machine so the spindle is not rotating but when I talked to the operator and he said that if he rotates the chuck to a certain position the alarm will go away. Would there be any correlation between the 2?
    Jun 2010
    161
    This alarm refers to a lack of spindle 'position' feedback (not X or Z axis servo feedback). Most lathes have an encoder on the spindle so you should look at it. Unplugging the spindle feedback cable on a working machine would produce the same alarm. It does not relate to the velocity feedback, so that is why the spindle may still be able to operate in M3/M4.
    Sep 2007
    371
    Check the spindle encoder cable, it seems that it is broken.
    Sep 2007
    371
    Oh, you got that from cnc2149...
    Apr 2011
    13
    Thanks, that helped and it looks like we found the problem.
    :wave:
  1. Replies: 2
    Last Post: 11-24-2018, 09:15 PM
  2. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  3. 401, 410 ALARM Fanuc O-T
    By F-Stop in forum Daewoo/Doosan
    Last Post: 11-28-2011, 06:39 PM
  4. Fanuc 424 alarm
    By DALEK in forum Fanuc
    Last Post: 01-21-2009, 06:27 PM
  5. Fanuc OM-0 alarm
    By yuem in forum Fanuc
    Last Post: 06-25-2006, 07:44 AM
