I fired up my machine after sitting for several months. I turned it on along with the computer to warm it up. While moving some stuff around the power strip that my computer was plugged into shorted and popped the breaker.
This may be two separate things... my computer will not boot (didn't before the short) and now the mill will not operate.
This is a version 1 machine. The control panel will not come to life though I get a beep with the 'start' and 'stop' buttons and the coolant will operate... nothing else.
I pulled the control board and found this under the LCD screen... upper left corner.
I'm pretty sure 'L1' is not suppose to be a tiny charcoal bricket. Any idea what this component was?
I'll put a call into Phil and see if they have any of these boards around.
The machine had been worked well for several years and did a lot of milling.
I now believe it was an inductor. Does anyone know the value of this component?
